Extended oil filter ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2006, 07:21 PM   #1 (permalink)
etc
View etc's Photo Gallery
2000 CE 2.2L 5 spd
what's a good extended filter to use for this engine?
etc is offline   Reply With Quote
Old 07-15-2006, 08:25 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
You can use the larger filters that some Toyota 4 cylinder engines use such as those for the 1.6l 4AGE
2007 Camry 2.4L 5M
Old 07-15-2006, 10:39 PM   #3 (permalink)
etc
what's the model name?
Old 07-16-2006, 02:43 PM   #4 (permalink)
Try 1986 and newer Corolla GTS if you're searching for the car model
I believe that the 2.4l 2AZ-FE engines in the newer Camrys use the same filter also
If you have a NAPA near you, the filter is Napa Gold 1396 which is about 1/2"-1" longer than the 1394 filter. Gasket and thread is the same.
I only know the Napa part number because I use those filters all the time.
2007 Camry 2.4L 5M
Old 07-16-2006, 04:03 PM   #5 (permalink)
etc
That's it, just 1/2" - 1" longer?
Old 07-16-2006, 06:21 PM   #6 (permalink)
Other manufacturers such as Purolator make equivalent filters, and I have used them, but that's the only larger filter that I know will fit.
Toyota only has two size filters for 4 cylinder engines and those are it. The only difference is that one of them is 1/2" to 1" longer.
2007 Camry 2.4L 5M
Old 07-16-2006, 06:37 PM   #7 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
How extended? Why extended? On my Camry I use Mobil 1 synthetic extended performance 15,000 mile oil with Mobil 1 Synthetic filter and change it every 10,000 miles. If you are running regular oil go with 5,000 miles oil change and oil filter interval.
JMSinMD is offline   Reply With Quote
Old 07-17-2006, 10:22 AM   #8 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
When you say larger, do you mean taller?
I use the imzfe filter for my 2.2. its taller and i like that its got more grip to remove when the times comes. The diamater is the exact same, i think the filter ends withpart number 1zz
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 07-17-2006, 02:50 PM   #9 (permalink)
View marc780's Photo Gallery
Extended oil filter? If by "extended" you mean extended mileage - I have an issue with the concept, so i won't use them on my own engines.
The oil filter protects the engine from dirt, dirt causes wear that destroys your engine. That little can full of paper will only hold so much and last for so long. And considering the environment of extreme heat it operates in, i'm pessimistic on long life filters being able to do anything but cost you more when you buy it.
I buy the cheapos and change em often, 3,000 mi or so along with the oil. Just my opinion, i could be wrong though.
Old 07-17-2006, 09:31 PM   #10 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
i know these are motorcraft numbers but toyota uses a ford sized boss, use a fl1a if nothings around it, or a 400 if there is, wix is 51515 for the big one and cross the 400 to wix
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
2005 Avalon XL Oil Filter anndel 3rd Generation (2005-2012) 9 04-01-2008 06:04 PM
K&N Performance Oil Filter vs Toyota OEM oil filter NewRacer Camry & Solara Lounge 18 06-06-2006 04:27 PM
Oil Filter Wrench BenG Hardcore Tech and Competition 12 07-22-2003 10:01 PM
