Ranger, it says the smoke smell like electrical. No Coolant smell, or oily, like maybe PS fluid. Which fluid levels have gone down? From your post, probly none.
The water pump is driven by the timing belt and it is out of sight, under the timing belt covers. Accesry belts drive the following - A/C, power sterring, alternator. Sounds like the alternator is conking out, belt is loose, electrical load way to high somewhere...My only guess o nthis scenario, Small coolant leak is spraying alternator, killing its bearing, or maybe shorting it????
