Removing radiator.. Few questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2006, 09:20 PM   #1 (permalink)
View Muddassir's Photo Gallery
3rd Generation Removing radiator.. Few questions
I almost removed all parts that I was suppose to except two things
- one electric connection to the right side fan near cruse control acturator cover
- cruise control acturator cover.
Can anyone guide me how to do that..
I am really amazed how am I unable to figure out how I can't disconnect an electrical connector..
Suggestions are welcome
Muddassir is offline   Reply With Quote
Old 07-15-2006, 10:09 PM   #2 (permalink)
View toyomoho's Photo Gallery
Some plugs have a built in plastic catch. This prevents the plug from just being pulled out. Look around on the sides of plug to see if you can find where to press and release the catch. The manual says something about removing the cruise control actuator wire clamp.
Old 07-15-2006, 10:14 PM   #3 (permalink)
its fan wire clamp..
And I am asking for cruise control acturator cover. I tried but couldn't remove it.. I removed one bolt from it too..
Old 07-15-2006, 10:45 PM   #4 (permalink)
View duke_togo's Photo Gallery
3rd Generation
For the cover, find the plastic tab/cap on the same side and use a flat head screwdriver to work it out. I just did this the other day to get at my starter.
For the connector, if it's the bigger grey one towards the front of the car, you need to press down on the tab/release and pull. Not sure which one you are talking about though, you might want to take some pics.
Hope this helps.
1996 Toyota Camry V6 LE (1MZ-FE A541E), gone, but not forgotten.
2006 Toyota 4-Runner SR5 V6
2011 Toyota Prius
duke_togo is offline   Reply With Quote
Old 07-15-2006, 11:36 PM   #5 (permalink)
Thanx duke_togo.. I already disconnected the connector.. I hope that the plastic tab thing would work out.. I thought that plastic tab was support on axis. thats why I wasn't touching it
Old 07-16-2006, 12:02 AM   #6 (permalink)
Hey..
I removed the round plastic tab, but it is stucked from the other side now.. And I can't find any screw at all to release it..
Any ideas?
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
2000 camry questions dimask 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-06-2006 09:14 PM
Celica modding questions! Help please? Vinny-Cent Celica Forum 12 10-31-2005 04:59 PM
Removing yellow reflector from Gen 2 Solara michaels_artic_ Solara 7 01-24-2005 02:26 PM
A Few Questions zeroscore Yaris, Vitz and Echo Forum 0 08-03-2004 12:11 PM
