:: will this light set up will work?? HELP!! :: - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2006, 04:49 AM   #1 (permalink)
iTrader Score: 6 reviews
View [khumbmela]'s Photo Gallery
hello tner's.. well today i hooked my fog lights up and it was good.. thnx for all the help btw.. u huys are good.. anyways.. i was cleaning my room and found a neon lights that i ordered back last year that i totally forgot and now i want to install them.. 2 under dash and 2 on the back seat.. well i am just wondering if this set up will work.. i will only going to use 1 switch for foglights and neons.. pls. help and advice me before i do this.. any comments are welcome.. thank you
[khumbmela] is offline   Reply With Quote
Old 07-18-2006, 04:56 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
You'll want to run relays on those fog lamps.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 07-18-2006, 05:03 AM   #3 (permalink)
so where should i put it?.. i don't have any relays right now on my fog lights and it works fine..
Old 07-18-2006, 07:28 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Wire up the foglights like this:
Use a 12V automotive relay. Either SPST or SPDT.
http://www.nteinc.com/relay_web/R51.html
"Skoolin' the unlearned!"
Old 07-18-2006, 11:10 AM   #5 (permalink)
^cool.. thnx.. so should i do the same on my neons?..
Old 07-18-2006, 04:30 PM   #6 (permalink)
VeeZed
I have two underdash neons hooked up straight to my incabin illumination (dome light circuit basically) without an problems. They don't draw that much power..about 200mA each. If your running 4 of them, just check the fuse in the circuit to make sure it can handle it. If not, then yeah you will need to run a relay for those too.
Old 07-19-2006, 05:05 AM   #7 (permalink)
cool.. thanks for repky.. i'll post my pics after i am done..
reset procedure Service Maintenance Reminder Light Suikelley 2nd Generation (2004-2010) 1 08-18-2007 11:24 AM
Prison VS. Work Cyorke Off Topic 10 01-19-2006 05:50 PM
Help! Can't get Wi-Fi to work! Eye8Pussies Off Topic 8 01-09-2006 04:09 AM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 04:56 AM
help with light mods....sigh.... JadeButterfly Camry & Solara Lounge 6 03-08-2004 09:15 AM
