v6 p0125 cel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2006, 01:04 AM   #1 (permalink)
View sajnaj's Photo Gallery
3rd Generation v6 p0125 cel
ok i have a 96 2dr v6 i recenetly changed my radiator. couple days later had a exhaust leak got it fixed and stil have cel. my check engine light came on i went to advanced autoparts and they gave me this code
po125
closed loop fuel control insufficient coolant temp
i have no idea what this code means any tips will be helpfull
thanks jason
sajnaj is offline   Reply With Quote
Old 07-19-2006, 07:47 AM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
it basically means that the coolant isn't at a warm enough running temp. Check to see if your cooling fans are constantly on and also check your thermostat.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 07-19-2006, 09:50 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
there a temp sensor thats what is bad.
^ and leaving it that way!
Old 07-19-2006, 02:15 PM   #4 (permalink)
Gameroom cash: $304355
Agreed. Check the engine coolant temperature sensor (Toyota calls it an ECT sensor) with a DVM and the specs from any manual. There is a generation 3 manual stickied at the top of this forum.
Mike
Old 07-19-2006, 02:49 PM   #5 (permalink)
is it ok if it runs like this
Old 07-19-2006, 02:59 PM   #6 (permalink)
Probably not. The default is probably running a richer than normal fuel mixture. Long term this could damage the cat converter. If it is the coolant temperature sensor, it's a relativley cheap fix. Get it fixed soon.
Mike
CEL CODES P1135 and P0125 tskelton 3rd & 4th Generation (1992–1996 & 1997–2001) 6 07-09-2006 05:03 PM
Toyota Tacoma lexusis350 Toyota News 12 10-28-2005 02:15 PM
CEL 99 V6, Codes P0446 & P1135 Galvatron Camry & Solara Lounge 4 04-05-2005 06:17 PM
V6 supercharged Tundra? ASEmaster 1st Generation (2000–2006) 7 03-24-2005 10:09 PM
92-96 Camry LE V6 suspension- supposed to be firmer than 4-cylinder? 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 6 09-20-2003 02:33 PM
