No Cat or High-Flow Cat...???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2006, 03:27 PM   #1 (permalink)
Camryologist
ptycamry's Avatar
View ptycamry's Photo Gallery
4th Generation No Cat or High-Flow Cat...????
Sup guys..
I have a 1998 XLE V6...
I've been thinking about doing something with my exhaust system..
I already have a MagnaFlow muffler...
I've heard many people say that if you remove the Catalytic Converter from the exhaust system and replace it with a same or slightly larger diameter pipe instead, it would give you a noticeable better acceleration and a bit more performance... However, this would make the car much more noisy...
My other option is removing the stock Cat and buying a Stainless Steel Mirror Finish MagnaFlow Cat... Would this give me more performance without going to the noise problem...??
What would you suggest..???
Thanks for the input...
ptycamry is offline   Reply With Quote
Old 07-19-2006, 04:34 PM   #2 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
Just put in the high flow cat, you will gain performance, but not have a load exhaust that stinks.
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 07-19-2006, 04:55 PM   #3 (permalink)
View AutoBox's Photo Gallery
a high flow cat would be more noticable with performance if you went turbo
it's known that no cat + exhaust = louder idle and different note.
but you've got a good muffler on there so i don't think it would get raspy or annoying.
anyways with a high flow cat it will sound louder because your opening up you exhaust more. it should still sound deep and throaty with your current exhaust, because your muffler does a good job in silencing down the exhaust already
AutoBox is offline   Reply With Quote
Old 07-19-2006, 06:07 PM   #4 (permalink)
View Forced Induxion's Photo Gallery
They're called test pipes... dunno if camry's have a sensor on the cat but if they do then most likely you'll get a CEL from one. They're also definitely alot cheaper than getting a hfc. Sound is usually pretty nice with a test pipe...plus a little exhaust smoke on WOT. If you got a huge turbo, maybe some flames out the pipes.
2002 Metallic Silver Audi A4 1.8T Sport/Premium Package
2004 Aspen White Volvo S60 2.5T Sport Package
2006 Alabaster Silver Metallic Honda Accord 2.4L Special Edition
2007 Super White Toyota Camry 2.4L LE
Forced Induxion is offline   Reply With Quote
Old 07-19-2006, 07:42 PM   #5 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
I just had a Magnaflow muffler for a while and recently got a 2.25" exhaust done. I have 2.25" piping from the flex pipe (no cat) to a 2.25" resonator then 2.25" piping to the Magnaflow. It has a beautiful sound at idle and screams when you floor. I just added a CAI (thanks 2wickedtoyz) and it now sounds a tad bit raspier but still sounds alright. I'm also getting headers in the next few weeks. Should sound decent as a whole (headers, cai, 2.25" piping w/Magnaflow))
The shop where I had the exhaust done just went ahead and removed the cat without me knowing. When I first looked under the car I was like WTF? where's the cat? I called the shop and they said they removed it because most people who tune their cars and upgrade their exhausts usually remove them anyway. He also added how down here in Fl there aren't any emissions so it doesn't really matter.
Everyone has their own arguments and opinions, but I don't have a cat and i'm fine without it.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is online now   Reply With Quote
Old 07-20-2006, 09:37 AM   #6 (permalink)
Camryologist
ptycamry's Avatar
Anyone has an idea of this..?? Does a Gen 4 V6 has a sensor on the Cat...?? This would kill my plans of removing it...
Old 07-20-2006, 09:47 AM   #7 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
there is NO sensor on the converter., the only sensors in the exhaust system are the o2 sensors.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 10-11-2006, 08:57 AM   #8 (permalink)
Camryologist
ptycamry's Avatar
Bringing the thread back to life... I haven't done anything with my exhaust cat yet, just wanted to know if someone else has an opinion on this to see if I can come to a conclusion...
Thanks a lot..
Old 10-11-2006, 11:26 AM   #9 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Incorrect... There are no sensors on YOUR Non CA / Non NY emessions 3vz-fe.
Thanks a lot..
If your cat is in good shape, you'll only see afew horsepower around the peak horsepower & higher. Might add up to around 5.
Having built afew test-pipes. Just use a mechanical o2 simulator. Buy yourself a spark plug antifouler. Drill the inside out so the sensor has about 1mm of room. Then thread the inside to accept the o2 sensor, weld that on your pipe & be done with it.
My suggestion is to forget the test pipe for now & build a y-pipe. Unless your cat is clogged, you're only going to get alittlebit with a test pipe. The test pipe can be done at the same time as the y-pipe also.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 10-11-2006, 06:25 PM   #10 (permalink)
Camryologist
ptycamry's Avatar
We don't have emissions controls in my country, my Camry is JDM, so I think I don't have sensors in my cat..
I'd like to know what would exactly happen if I remove my cat, and what diameter "test pipe" I should put in to fill that space.... Same size, bigger, smaller..??
Old 10-11-2006, 06:38 PM   #11 (permalink)
Toysrme's Avatar
Cool
The same size. Being an OBD-II computer, it still most likely has both a cat & a post cat o2 sensor. Hello mass production. If you have one & ditch it. You'll be graced with a CEL & possibly different tables.
Now with Turbo!
Old 10-12-2006, 12:02 AM   #12 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
My car had 3 cats on it and I removed one. I don't notice that much of a difference, it does sound louder though with 2.5" piping and the removed cat.
The two cats were on the Y pipe with some sensors somewhere around them, i forgot
that's on my gen 5
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 10-16-2006, 08:14 AM   #13 (permalink)
Camryologist
ptycamry's Avatar
Has anyone actually removed the cat on a Gen 4 V6...??? I don't wanna make a decision "hoping" there's no sensor on the cat...
Old 10-16-2006, 09:13 AM   #14 (permalink)
Toysrme's Avatar
Cool
There being a post-cat lambda O2 sensor is not really in question. It's an OBD-II spec car. It's got the sensor. Just use a mechanical o2 simulator on it.
Seriously tho. Just look under the car...
Now with Turbo!
Old 10-16-2006, 11:30 AM   #15 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
just listen to what toysrme is saying- even if you have a post-cat sensor (which you probably do), a simulator will do the trick
HaHa
hi flow cat Chico Camry & Solara Lounge 5 04-03-2003 10:46 PM
High flow Cat??? wontonjohnny Camry & Solara Lounge 10 12-10-2002 11:27 PM
high flow cat ? DrtySthV6SE Hardcore Tech and Competition 29 12-10-2002 04:57 PM
