clutches - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2006, 09:30 PM   #1 (permalink)
View 32oz.'s Photo Gallery
clutches
well i dont need one just yet. but i am wanting to plan ahead and set some money aside. what clutches are offered that are a step above just a regular OEM clutch. but nothing hardcore. i dont plan on ever having much power. maybe intake, header, exhaust. thats most likely it. and suspension junk .. im a junkie when it comes to suspension. it has to be set up good or im not a happy camper.
so yeah .. what clutches is everyone running?
1991 4cyl 5speed 20% tint stock as a rock w/203,xxx and counting
32oz. is offline   Reply With Quote
Old 07-20-2006, 10:16 PM   #2 (permalink)
etc
View etc's Photo Gallery
I have the same question.
etc is offline   Reply With Quote
Old 07-20-2006, 10:22 PM   #3 (permalink)
2nd Generation
well .. we will wait for an answer
Old 07-21-2006, 02:20 PM   #4 (permalink)
View marc780's Photo Gallery
The stock clutch is pretty good, good for most mods i should think. I think when you go for a stronger clutch that means stiffer springs in the pressure plate - which might affect foot pressure at the clutch pedal. In other words, install the wrong clutch plate and you now own a 2500 pound exercise machine for your left leg.
Old 07-21-2006, 03:40 PM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308075
Most of the low-end upgraded clutches aren't much of an exercise for your left leg... ACT, Exedy and Spec all make good clutch kits. You'll want a 'stage 1' or 'street' or similar kit. I believe kits that fit a 5s-fe car also fit the 3s-fe Camry.
-Charlie
(I have a Spec Stage 2 for an MR2 on my swap - which can handle around 400ft-lbs of torque and its not much stiffer than stock)
white90dx is online now   Reply With Quote
Old 07-21-2006, 07:44 PM   #6 (permalink)
2nd Generation
so just a small step above stock? cool. yeah about the pressure .. im not afraid. i used to have a mustang or two with heavy duty clutches and pressure plates. and i had to just get used to it, or else i didnt get to drive my car. so i actually want a little extra pressure because this pansy ass clutch is throwing me off its so lightweight. dont get me wrong, its a nice change, but still, for better driving habits i would like it a little stiffer.
Old 07-21-2006, 07:52 PM   #7 (permalink)
2nd Generation
"Dual Friction Clutch Disc And Pressure Plate (90% increase in holding capacity) - 2WD 2C,3SFE 2.0L Engine - from 5/90"
-centerforce clutch kit i found.
i really like exedy tho. couldnt find an application for the 3sfe
Old 07-21-2006, 07:57 PM   #8 (permalink)
white90dx's Avatar
Cross reference the part numbers for ACT or some other manufacturer. You should be able to tell what parts cross over to the 3s-fe from the 5s-fe or other car. (well, actually its the tranny that matters - and both the 5s-fe and 3s-fe Camrys use the same transmission, pretty much)
Oh, and when I said the pedal pressure was about the same, I was from memory - it has been over 8 months since I felt the stock Camry pedal.
-Charlie
Just wondering something about these clutches. hyperlitewkbrdn 2nd Generation (2005+) 10 07-14-2006 11:20 AM
ae95 4x4 clutches big_fella6699 Archived Corolla threads 3 05-09-2006 06:13 AM
Tell me about clutches: kenratboy Camry & Solara Lounge 20 07-13-2004 01:26 AM
Exedy clutches tightcamry129 Camry & Solara Lounge 7 03-10-2004 10:01 PM
Clutches RiCebuRneR206 Camry & Solara Lounge 2 07-27-2003 01:19 AM
