Rim Size Reco with pic - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2006, 08:00 AM   #1 (permalink)
View RockXP's Photo Gallery
Gen6 Rim Size Reco with pic
Can someone recommend me a good size rims. I have an LE I4 so I dont want to pick the wrong size and make the wheels look skinny or get an oversize rim that will mess up the look of the car.
http://www.1010tires.com/wheel.asp?w...lmodel=Koblenz
I like these rims the BEST. I am still undecided about if I should get 18 or 19 inch. In the website what does the offset (mm) mean?
Thanks
RockXP is offline   Reply With Quote
Old 07-22-2006, 03:48 PM   #2 (permalink)
bump
Old 07-23-2006, 10:23 PM   #3 (permalink)
07CamrySEV6's Avatar
View 07CamrySEV6's Photo Gallery
USA
Uh, sorry to tell you, but someone already has these wheels installed on their 07 Camry. His username is SupermanCK. Go search for his posts. He posted several pictures of his Camry. You might want to chose another to be unique and different.
07CamrySEV6 is offline   Reply With Quote
Old 07-23-2006, 10:35 PM   #4 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
What color is your Camry? On a side note, if you care about performance (not sure since you have an I4), you should get 18's to reduce the weight of the wheels.
Epsilon is offline   Reply With Quote
Old 07-23-2006, 10:41 PM   #5 (permalink)
Epsilon's Avatar
Forgot to answer your question, the wheel's offset is the distance from its hub mounting surface to the centerline of the wheel. We can tell you what offset would fit if you tell us the width of the wheels.
Old 07-24-2006, 02:12 AM   #6 (permalink)
Thanks for getting back to me. I know SupermanCK has these wheels, that is how I found them. My car color is Silver (titaium metallic). I was thinking 18x8 with offset 35 or 18x9 with offset 35. Im assuming the 8 and 9 are the width?
Old 07-24-2006, 02:30 AM   #7 (permalink)
Epsilon's Avatar
If I remember correctly, SupermanCK has 19x8.5 on his car and he has no rubbing problems. Since you're car is silver, I would recommend a gunmetal finish with a polish lip, which would also accent your black tint, assuming you have it. Too bad the wheels you want only comes in silver or dark black.
Old 07-24-2006, 02:31 AM   #8 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Click the Affiliates link at the top of the screen and look for 6061 Forged. They have 19s that weigh 18lbs
2007 Camry 2.4L 5M
1990 V6 Rim Size blkdmnrcing 1st & 2nd Generation (1983–1986 & 1987-1991) 3 12-13-2005 07:31 PM
What size tire on a 16" or 17" rim pasty64 Tercel, Paseo, Starlet, and Sera Forum 1 11-11-2005 10:58 AM
Which Rim Size Rules the Road RICO8458 Camry & Solara Lounge 8 10-18-2005 09:01 PM
Bolt Pattern/ offset / center hub size for 91' V6 stock rim? NBC 1st & 2nd Generation (1983–1986 & 1987-1991) 1 03-30-2004 03:25 PM
ImportFest IS rim pic (large) EKam General Discussion 0 09-29-2001 10:09 PM
