brake lights. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2006, 03:38 PM   #1 (permalink)
View hellomota's Photo Gallery
brake lights.
First I got the warning light on, sayind something wrong with the tail lights, so I check them and both of the brake lights on the sides are out. So I pop the cover and both the bulbs are burn, I change bulbs and nothing hapends, I measure the voltage and nothing comes to wires when I press brake. The middle, window brake light works just fine by the way, all the fuses work good as well, please help me locate the problem. Thanks Greg.
hellomota is offline   Reply With Quote
Old 07-22-2006, 03:40 PM   #2 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
check the wiring near the trunk hinge. its a common problem, the wires there get brittle and break after repeated opening and closing of the trunk.
LE05 is online now   Reply With Quote
Old 07-22-2006, 03:47 PM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
you need to check for output voltage at the brake light switch. check all of the bulbs for good measure. they're not in series, so it wouldnt matter if one were burned out.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 07-22-2006, 03:55 PM   #4 (permalink)
mazdaverx7 where is the brake light swtich located?
Old 07-22-2006, 11:25 PM   #5 (permalink)
Gameroom cash: $304355
Since the high mounted (back window) brake light works, his brake light switch should be fine. He most likely has broken a wire or 2 in the wiring loom located inside the trunk near the driver's side hinge as LE05 suggested.
Mike
Brake Lights Won't Turn Off usadaytrader 2nd Generation (2005+) 4 03-05-2010 12:10 PM
3rd Brake Light and Bed Lights Toyfox303 2nd Generation (2005+) 32 09-21-2006 11:21 PM
Brake Lights Wolfcastle Archived Corolla threads 14 08-16-2006 11:55 PM
Charge AND Brake Lights on-HELP! Longstreet Pre-88 Toyota Pickup/Hilux 14 08-13-2006 11:40 PM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 07:17 PM
