GREETINGS!
i have a 92 camry. only one of my power windows [drivers door] is working. i have the door panel removed as i've read here and understand the wires can break/detiorate in the vicinity of where they pass through the door.
1- how do you "peel back" the rubber boot at the door enough to see the wires inside it?- does it have to be cut? mine will not slip back enough in either direction to see ANY wires.
2- is the area of the broken wires usually under the rubber boot between the door and the body, or where they actually pass through into the door? how do you determine which wires need to be repaired if they or the insulation is not visibly damaged?
3- how do i isolate the problem to be in the wires and not the switches?
any other tips or info related to this repair would be greatly appreciated!
happy motoring,
chris
