Ignition Coil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2006, 03:15 PM   #1 (permalink)
View Camry093's Photo Gallery
Ignition Coil
Hey guys, I'm trying to remove the ignition coil on my 93 4 cylinder. I removed the two screws from underneath, but it's still stuck, are there more screws or is it locked in somehow? I'd prefer not to pull the distributor.
Thanks,
Vic
Camry093 is offline   Reply With Quote
Old 07-23-2006, 07:16 PM   #2 (permalink)
Just realized that there are 4 screws for the coil, the back two are nearly impossible to get at unless you pull the distributor. I took out the two bolts holding the distributor to the head, but it won't come out, any suggestions?
Thanks again,
Vic
Old 07-23-2006, 10:05 PM   #3 (permalink)
Sebastian Loebs evil twin
BakaWill's Avatar
View BakaWill's Photo Gallery
pull harder i guess. the 2 bolts should be the only thing holding it in. but make sure you mark how the distributor relates to the head other wise youll have to re time the engine with a timing light.
1990 camry dx 3s-fe
BakaWill is offline   Reply With Quote
Old 07-24-2006, 12:05 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140995
yeah, what bakawill said. once the distributor breaks loose, it should easily slip out. replace the o-ring while youre at it!
ghettosled is online now   Reply With Quote
Old 07-24-2006, 02:14 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Like everyone says, mark the position of your distributor body so you can replace it in the same orientation (mine happened to be exactly the width of an allen wrench in the adjustment groove. ). Make a note of which direction the rotor is pointing (if you forget, you have a 50% chance to be off by 180 degrees). Now, gently twist the body of the distributor like you were adjusting the timing. Once it rotates you should be able to wiggle it out. The only thing holding it in is an o-ring. The o-rings get brittle. It would be best to buy a replacement (I think about $10). If you decide not to watch for oil on the top of your transmission for a few weeks afterwards.
Watch out for the sensors nearby. They break if you happen to put any force on their plastic tops.
Kep
Old 07-24-2006, 07:47 PM   #6 (permalink)
Thanks guys, got it out. Had a nice crack in the coil.
Ignition Coil Amplifiers - Do they damage your Ignition Coils? Ken4 Camry & Solara Lounge 2 06-29-2006 02:32 AM
Do the Ignition Wires and Coil Packs ever need changing? Ken4 Camry & Solara Lounge 16 12-16-2005 07:24 AM
Question/Help about Ignition Module and Coil TheOtherSide Camry & Solara Lounge 3 09-27-2005 07:29 PM
MSD ignition coil - safe for MR2? StuckInNeutral MR2 Forum 10 10-12-2004 09:08 PM
