removing the cat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2006, 07:41 PM   #1 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
3rd Generation removing the cat
am i ok if i remove the cat on my 94 1mzfe it has an o2 sensor after it so that kinda detered me for a while. i just want to know if there was anybody who did the same?
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 07-23-2006, 09:28 PM   #2 (permalink)
2 8
View 2 8's Photo Gallery
don't you have emissions in FL?
2 8 is offline   Reply With Quote
Old 07-23-2006, 09:56 PM   #3 (permalink)
View toyomoho's Photo Gallery
Check the county where your car is licensed to see if an emission testing is required. If yes, the lack of a converter will cause the car to fail either the inspection check or tail pipe emissions test.
Old 07-23-2006, 10:13 PM   #4 (permalink)
Gameroom cash: $368676
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I think you're car would actually run slower without it reading properly. I guess the computer will read and try to compensate improperly to fix the problem (so i heard). Anyway, some guy at an exhaust shop said they have $10,000 fine if you're caught without a cat. I'll save that trouble and the noise from not having one
RichieRichJP is offline   Reply With Quote
Old 07-23-2006, 11:40 PM   #5 (permalink)
View mspringer's Photo Gallery
You can get a high-flow cat, which is legal and will flow better, but I wouldn't bother doing that, or deleting the cat. These motors aren't making enough power / exhaust pressure to make much additional power without a cat or with a high-flow cat. With a turbo or supercharger, then maybe it would make sense.
By the way, if you have a downstream O2, then the car WILL throw a code if you delete the cat, unless you have O2 simulators connected.
mspringer is offline   Reply With Quote
Old 07-24-2006, 01:42 AM   #6 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
Your okay, just flange a pipe if you need to put the cat back on.
-SCWEET1- is offline   Reply With Quote
Old 07-24-2006, 01:59 AM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
or do the old, gut the cat trick, so that it will still pass visual inspections
HaHa
P0420 Code and Replacing Cat - Need Help Denadai Archived Corolla threads 4 04-26-2010 12:59 AM
Need some idea from cat owners. itzsteven Off Topic 13 08-27-2005 11:18 AM
Cat Heaven MR2Jedi Off Topic 2 04-13-2005 12:07 PM
Hollowed out front cat. you think it will cause an CEL EMMETT03 Camry & Solara Lounge 10 01-09-2005 09:45 AM
Removing Cat hdsalinas Archived Corolla threads 4 08-30-2004 09:39 PM
