Anyone help, cruise control prolems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2006, 06:08 PM   #1 (permalink)
View grancpe's Photo Gallery
I have a 95 camry wagon and the cruise control doesn't work. It will surge and let off the throttle trying to find the correct speed. This seems to happen at all speeds. It is NOT vacuum controled. Anyone have a clue. Thanks.
grancpe is offline   Reply With Quote
Old 07-26-2006, 11:09 PM   #2 (permalink)
View toyomoho's Photo Gallery
Does this car have a cruise control light on the instrument cluster? If so, do this light blink when the cruise control is malfunctioning and does the cruise control turn off? If is does, a trouble code might be stored in the ECU for later readout. If the light blinks the problem could be one of the following: Cruise control actuator, speed sensor on trans, throttle position sensor, a problem with the transmission.
If the cruise control stays on and light does not blink, it could be the actuator control cable is not adjusted correctly or the cruise control ECU. The cable goes form the large black box next to the battery and the throttle valve.
Old 07-27-2006, 12:59 AM   #3 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Some cruise controls have a box with a wheel being turned by the cable. A sensor reads the speed of the wheel (which has holes or metal strips etc.). The wheel can get dirty or the sensor or circuitry becomes faulty, (broken solder joint, perhaps).
Dave's is offline   Reply With Quote
Old 07-27-2006, 12:40 PM   #4 (permalink)
View Ruchi's Photo Gallery
3rd Generation My cruise does this too
With my 93 LE, the cruise rarely will work for more than a few minutes, unless the road is completely flat. The light starts to flash and it disengages. You have to turn the car off and restart the car in order to reset the cruise control to use it again. I've been wondering if this is a simple fix, but nobody has posted anything yet. It's pretty common I believe.
Ruchi is offline   Reply With Quote
Old 07-30-2006, 07:59 AM   #5 (permalink)
Thanks for the suggestions, I will check into it and see what happens.
Old 07-30-2006, 12:35 PM   #6 (permalink)
Dave's
For those which are vacuum controlled, you may need to add a vacuum canister. Had one which did almost Ruchi's and that's what it took. Going uphill or under heavy acceleration it would lose vacuum and kick off. But it took months to figure it out.
Old 09-07-2006, 06:56 AM   #7 (permalink)
Thanks I will try that.
Old 09-07-2006, 09:45 AM   #8 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
Look for the cruise control actuator next to the battery behind the radiator. The actuator is concealed beneath a cover at the other end of the cable connected to the throttle body. Look for a loose or disconnected connector on the front of the cruise control actuator. Might just be the electrical connector on the cruise control is loose. See if taking the connector off and pushing it back on solves the problem.
One other option is the brake light switch. Pressing the brake disengages the cruise control. The switch maybe loose and need adjusting or may be worn out and needs replacing. If out of adjustment it may short out periodically.
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
