Update, the cigarette lighter light runs between the same junction boxes as the rear window defogger, A/C switch, blower switch, A/C control assy and ashtray lights. The wires for these lights are Black and Green. Power comes from the 7.5A Panel fuse. If the hazard light works, power should be getting to the junction box that supplies power to these lights.
Check the bulbs and see if the wires running from the lights that do not work are connected to the junction boxes.
The radio gets its power from the Radio No1 and Radio No 2 fuses. Check to make sure the radio is getting power at the Gray and Blue/Yellow wires. The radio lights seem to be internal to the radio. If the radio is getting power, the lights should work unless there is a problem with the lights or inside the radio..
