O/d - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2003, 08:19 PM   #1 (permalink)
View prazeo's Photo Gallery
Question O/d
can anybody explain to me what that O/D button does on the gear shifter? (98 by the way)
i understand its overdrive but im clueless to its function..
prazeo is offline   Reply With Quote
Old 03-28-2003, 10:38 PM   #2 (permalink)
_
View vkeks05's Photo Gallery
With O/D off, the highest gear availble is 3rd gear.
With O/D on, 4th gear is availble, and that gear is used for mainly cruising at speeds above 45mph.
vkeks05 is offline   Reply With Quote
Old 03-29-2003, 01:27 AM   #3 (permalink)
KuRuPt ConCePtS
View Chico's Photo Gallery
so is it better to drive w/ it on or off normally???
Chico is offline   Reply With Quote
Old 03-29-2003, 02:32 AM   #4 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
jus keep it on......on for highway use, off for city.....but jus keep it on so u dun hafto struggle with it since u r rite now.
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 03-29-2003, 02:25 PM   #5 (permalink)
View Tex97's Photo Gallery
eh, I keep it on all the time. You could take it off in the city to warm your car up faster if you keep it under 3 grand.
When my car is cold it won't shift into 3rd gear till you hit 35mph. And then when it shifts, it shifts hard. I think this is built into the tranny to help warm the car up.
97' Camry XLE V6
Tex97 is offline   Reply With Quote
Old 04-04-2003, 12:11 AM   #6 (permalink)
which option saves more gas? does it depend...
Old 04-04-2003, 12:17 AM   #7 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
If conserving gas is your concern, change your driving habits. Don't take off when the light turns green. Don't stomp on the brake 2ft away from interesection. Don't drive over the posted speed limit. Otherwise, just keep O/D on and let the car's computer do the rest.
Phi is offline   Reply With Quote
Old 04-04-2003, 09:28 AM   #8 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
O/D means overdrive.
Overdrive means a transmisison gearing such that the output shafts turn faster than the input therefore lowering rpm.
Lower rpm means less fuel consumption (unless of course you are climbing a hill and lugging the engine) <<<-- Lugging the engine with an automatic with electronic control (which you have) is nearly impossible.
When your engine is cold the electronic transmission control will automatically change how the transmission behaves to help the car (and its fluids) warm up faster with less stress. So you don't need to worry about changing it when the engine is cold.
Just put your car in D and leave the O/D on.
They only time you may wish to turn it off is when descending a long hill on the highway to allow for a bit of engine braking to maintain the speed limit without applying the brake as often. Don't forget to turn it back on.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 06-18-2003, 04:26 AM   #9 (permalink)
View MalooMAN's Photo Gallery
thanks heaps guys! it is good to know all about my auto now. Im still going to miss the great take-offs and the little more feel of power. it felt like a manual :p i liked it.
MalooMAN
Gen 2
115HP
stock everything :-(
CHECK IT OUT!
http://members.cardomain.com/malooman
MalooMAN is offline   Reply With Quote
