headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2003, 08:29 PM   #1 (permalink)
View prazeo's Photo Gallery
Question headlights
yeah i searched on this topic but couldnt find any answers...
i wanted to get some new hid type bulbs.
how exactly do you change your bulbs? open up the hood, unscrew the screws? is that all? because i didnt want to just start unscrewing stuff and find myself with a problem.
also, do you have to replace both low and high beams? is it essential? or can i just replace the low beams which i use predominantly anyway. i hardly ever use high beams.
and lastly, what brand bulbs give off better light than regular halogens? i understand that the bulbs with the blue coating give off less light.
thanks!
prazeo is offline   Reply With Quote
Old 03-28-2003, 08:38 PM   #2 (permalink)
View Yack's Photo Gallery
Try the search function again.
Yack is offline   Reply With Quote
Old 03-28-2003, 10:00 PM   #3 (permalink)
View Tubbyc's Photo Gallery
well.. first of all .. what year is your camry?
change light bulbs should be quite easy, I don't think you have to unscrew any screws if you have a Gen4 camry
basically, just read the owner's mauel, open the hood, disconnect the cable, either release the clip or rotate the bulb to remove it.
It is not essential or required to replace both the high beam and low beam bulb, you can replace whichever you want to..
I heard good things about Sylvania silverstar bulbs ..
you can also try PIAA or Razo..
Tubbyc is offline   Reply With Quote
