timing chains - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2006, 07:04 PM   #1 (permalink)
View 32oz.'s Photo Gallery
2nd Generation timing chains
3sfe motor. anything else i should/could do while swapping out the timing chain?
1991 4cyl 5speed 20% tint stock as a rock w/203,xxx and counting
32oz. is offline   Reply With Quote
Old 07-25-2006, 08:39 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
it has a belt drive
Old 07-25-2006, 09:03 PM   #3 (permalink)
View toyomoho's Photo Gallery
If a higher mileage engine, any idler and tension pulleys, tension spring, water pump if it has never been changed. Check the oil, crank and cam seals for leaking.
Old 07-25-2006, 09:09 PM   #4 (permalink)
2nd Generation
203,xxx . and thanks for the help. whats something like that gonna run?
Old 07-25-2006, 09:13 PM   #5 (permalink)
2nd Generation tires
so stock is 185/70-14. i was wondering what would handle better w/o getting new wheels. i was thinking 195/55-14. but tell me otherwise with your experience. my car handles like a .... i dunno, its not firm. and i know ... im doing the suspension as time goes on. the strut bar from whiteline ... or .... is it the strut bar? and then kyb struts and intrax springs. then see what shes gonna need from there.
-oh, 1991, 4dr, 5speed. bone stock. thought you may need to know that.
Old 07-25-2006, 09:27 PM   #6 (permalink)
One TN member quoted the dealer wanted $500 for parts for a 5SFE. Shop around at auto stores, on-line part dealers, Ebay even has sells these parts. As I recall I did the job for a 5SFE for under $200 in parts. But I shopped around before doing the job.
Old 07-25-2006, 09:37 PM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
check if water pump is still good while you'r in there
Old 07-25-2006, 10:16 PM   #8 (permalink)
2nd Generation
ha ha ... i meant to start a new thread. but lets also discuss this w/o moving it and trying to get a new thread.
Cam belts and timing chains DIY???!!!??? LYR Celica Forum 0 03-11-2006 05:52 AM
high mileage toyotas and timing chains sloppybeak 89-95 Toyota Pickup/Hilux 13 02-19-2006 07:44 AM
What year Camry's have timing chains? newbie212 Camry & Solara Lounge 6 12-21-2005 10:49 PM
2000 to 2002 only ones with timing chains???? redgtxdi Archived Corolla threads 6 08-30-2005 12:53 PM
