Originally Posted by Dave's
But you can replace the mast. About $20 and if your lucky, (the old mast hasn't broken yet) I think you can just pull the antenna out while it's running up. Then you feed in the new one while it's running down. Someone correct me if that's wrong, it's been a while.
You have to take the ring with the 2 slots in it off first. Then turn the radio on and the old mast should come right out in to your hands. Notice which way the teeth on the bottom plastic part go. Now feed the new mast back in slightly with the teeth pointed in the same direction and turn the radio off. The new mast should be pulled right in. When it is down, reinstall the ring.
Mike
