Originally Posted by godin
what i'm looking at doing to to get another engine from the junk yard 5sfe with a good blok and then rebuild it using mr2 pistons (to lower the compression and allow for more boost.
Bore on a 5S is slightly larger then a 3S. So pistons from a 3S-GTE (MR2 Turbo) will not work on a 5S.
Its not a problem though as you can buy pistons and rods for a 5S.
another question that i had was the ge head has 2 cogs on the end . one for each cam
the fe head has 1 cog and a transfer in side the head
what is the difference in performace.
G head has wider valve angle (45 degrees) vs. F head (22 degrees).
Ports on G head are bigger.
