Steering pulling right and left - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2006, 12:07 PM   #1 (permalink)
View nacra780's Photo Gallery
I replaced the struts and mounts and had a 4-wheel alighnment. I did this because of the wear patterns on the tires. If I take a right turn before going straight, the car has a slight pull to the right. If I take a left turn before going straight, the car has a slight pull to the left. It is like the steering will not go back to center on its own. I did not notice this before replacing the struts.
Any suggestions are appreciated. This is a 93 Camry, 4-cyl., 180k miles.
Thanks
nacra780 is offline   Reply With Quote
Old 07-27-2006, 02:25 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
changing the struts shouldn't make the steering do that- especially if you had a 4 wheel alignment afterwards
and how bad is the problem? and as well, have you had your steering rack checked?
HaHa
Old 07-27-2006, 02:40 PM   #3 (permalink)
The pull is not real bad?? The rack was leaking so I had it replaced about two years ago.
Old 07-27-2006, 02:44 PM   #4 (permalink)
View toyomoho's Photo Gallery
If you used a stock type strut and mount the steering should remain the same. Too much Toe-Out in the front wheel alignment will cause the car to want to enter a turn and stay there. Go back to the alignment shop and demonstrate your problem to them.
Old 07-27-2006, 05:35 PM   #5 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
also for shouts and laughs, check your tie rod ends. you may want to take the car back to the place that did the alignment and have them correct the problem. it obviously wasn't aligned properly if its pulling like that.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 07-28-2006, 01:06 PM   #6 (permalink)
Gameroom cash: $304355
"you may want to take the car back to the place that did the alignment and have them correct the problem. it obviously wasn't aligned properly if its pulling like that."
Agreed, especially if it wasn't doing this while you were driving to the alignment shop, after replacement of the struts.
Mike
