Air/fuel sensor vs an oxygen sensor HELP!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2006, 01:20 PM   #1 (permalink)
View tskelton's Photo Gallery
1998 toyota camry 2.2l 4 cyl
oxygen sensor goes bad (which i now believe to have been an air/fuel sensor) i understand the air/fuel sensor has a wider range than the 02 sensor. I replaced it with a universal oxygen sensor from advance auto parts. they said it was the part for my vehicle. i had the codes cleared and about 30 hours later the light came back on with code 1133 manufacturer controlled air fuel metering. is this because it is not an air fuel sensor? is it necessary to replace it with an air fuel sensor? i have tried searching and reading. all that has done is to thoroughly confuse myself. please help!!!
tskelton is offline   Reply With Quote
Old 07-29-2006, 07:26 PM   #2 (permalink)
why is it that no one will help me!!! im for real lost on this and really need some help!
Old 07-29-2006, 07:37 PM   #3 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
go to the dealership and purchase an air/fuel ratio sensor then. Make sure its the front one and not the rear O2 sensor
BadChicken is offline   Reply With Quote
Old 07-30-2006, 12:06 AM   #4 (permalink)
View hooRAH's Photo Gallery
The P1133 is a manufacturer specific code. I would give toyota a call and see the specific parts it refers to.
There is no such thing as an air/fuel sensor that is different than an oxygen sensor.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 07-30-2006, 05:42 AM   #5 (permalink)
View 91MR2quickNA's Photo Gallery
CA emissions A/T Camrys from 1998-on have A/F ratio sensors rather than O2 sensors. These are essentially wideband O2 sensors for better emissions control.
They ARE different. The A/F ratio sensor will have lower resistances between the terminal pins than the traditional O2 sensor. The A/F sensor is also grounded to the ECU not the chassis.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 07-30-2006, 08:00 AM   #6 (permalink)
View Ken4's Photo Gallery
So why dont they just call it a wideband 02 sensor?
Ken4 is offline   Reply With Quote
Old 07-30-2006, 06:41 PM   #7 (permalink)
ok so i know that i need to get an a/f ratio sensor...how much am i going to be looking at. I just dropped 80 buck on the universal o2 sensor...you think advance will refund me for the part since they sold me the wrong one? lol...gotta hope so right. but seriously...how much am i going to be looking at?
Old 07-30-2006, 08:13 PM   #8 (permalink)
The A/F ratio sensors on my 1MZ list for around $230 at the dealer.
I have 3 that I won't be using. It's the same 4-pin design as the A/F ratio sensors for the 5SFE. I tested the terminal pins, and they are in spec with resistances. Let me know if you want any of them.
Jason
1991 MR2 N/A (SW21)
Old 07-31-2006, 11:42 AM   #9 (permalink)
hey...well luckily my fiance's dad has an import auto shop. unfortunately its about 6 hours away. so he ordered the part for me..only like 140 thank you very much for the offer though.
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
1993 Toyota Pick-up Oxygen Sensor Wiring Shawn1977 89-95 Toyota Pickup/Hilux 3 05-11-2011 10:10 AM
Replacing Oxygen Sensor For corolla 98 1998corolla1998 Archived Corolla threads 13 07-05-2010 11:35 AM
Oxygen Sensor wire omegarex Camry & Solara Lounge 0 04-23-2006 10:57 PM
Oxygen Sensor/CEL rockyoyster 89-95 Toyota Pickup/Hilux 3 04-09-2006 09:08 PM
