- get the ECU rechipped for a higher rev limit. As for which chip, shop around.
- You will need to get a automatic ECU controller which changes the shiftpoint on automatics. Levelten (
http://www.levelten.com) has the upgrade available. You are looking at $1000 USD for this upgrade.
My suggestion -- swap a 5 speed if you want to rev. Even if your valvetrain and bottom-end can take the higher redline, your tranny won't. Most of the time, RPM = excessive heat to the tranny which will eventually lead to failure. There is something called "stall speed" for automatics; and a higher stall speed (matching your powerband) lets the engine stay in the best powerband for the longest possible time. It is better to get a higher stall converter upgrade opposed to upping the redline.
