Help. My Transmission Is tuck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2006, 01:05 PM   #1 (permalink)
View fastwrx's Photo Gallery
My 1993 Camry v6 automatic Transmission is stuck in park. What is the problem?
fastwrx is offline   Reply With Quote
Old 07-30-2006, 09:38 PM   #2 (permalink)
View toyomoho's Photo Gallery
Are you unable to move the shift lever from Park, or you can move the lever but the transmission stays in Park?
There is an interlock relay or cable that prevents the shift lever from being moved unless the ignition switch is in the ON or Access position and the brake on.
Check the ECU-IG, Cig/Radio and Stop fuses. The interlock can be bypassed by removing a small plug located on the shift level console just left of the gearshift lever. Once removed, you should see something white made of plastic. Push down on this to release the shift lever.
The Free Mod Series - Part I Quicker Transmission Shifting Toysrme Camry & Solara Lounge 153 03-01-2012 12:24 AM
HELP: Serious Transmission Problems arcasmachineracing Camry & Solara Lounge 23 06-22-2008 11:53 PM
Transmission for 95 4runner w/90 engine Mallenski 4Runner Lounge 0 03-13-2006 11:55 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
Mister Transmission in Markham Im_a_dickhead Feedback: Buyers, Sellers, and Vendors 4 07-31-2002 09:43 PM
