Originally posted by 89_cam
this past saturday i messing with my intake. i pulled the 2 screws that hold the wirin' harness to the mass air flow sensor out. then i couldn't pull the harness out so i put the screws back in a now my car wont start.
Some of the connections on the AFM (air flow meter) are probably broken.
You can cut open the plastic lid on top of it and see if you can fix it. If not you'll have to buy a new AFM.
By the way you don't need to remove the 2 screws to unplug the harness. The harness just unplugs. And its a AFM (air flow meter) not a MAF (mass air flow).
