Wheel Lock Nut broke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2006, 02:26 PM   #1 (permalink)
Registered User
View qprint's Photo Gallery
I was removing wheel lock nut with a 1/2" breaker bar and part of the lock nut broke off.
I'm still able to grip the nut with the key, but before trying this, should I soak the nut with Liquid Wrench or penetrating oil and then loosen with socket and wrench or tire iron or electric impact gun?
qprint is offline   Reply With Quote
Old 07-31-2006, 10:54 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check the link for suggestions:
Wheel Lock
Old 08-01-2006, 12:11 PM   #3 (permalink)
Registered User
I read the post and it was for those who could NOT grip the nut, I can grip it with the key lock but before I do, which penetrate oil and removable method should I use? Breaker Bar or Impact gun ?
Old 08-01-2006, 02:47 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
impact gun if you have one. and it wouldn't hurt to soak it with pbblaster or something, though if you can get a good girp still, there isn't really any point
and why did you even use a breaker bar if you had an impact gun??
HaHa
Old 08-01-2006, 04:00 PM   #5 (permalink)
The link stated the tire shop had a universal key they installed, and then drove it with an impact wrench.
Old 08-01-2006, 08:56 PM   #6 (permalink)
Registered User
I was out of town, and I only had a breaker bar. Anyhow I used Penetrating oil and let it soak in , then I used the breaker bar only to find out that it gripped better tightening the bolt than loosening it. I couldn’t do it, so I went for the impact gun and it broke the key. The nut on the wheel has only the center groove, so a new Key can be used. Now I should go to a tire shop, maybe the dealer to get this out. Might as well remove all the other key locknuts and replace with original nuts.
Old 08-01-2006, 11:17 PM   #7 (permalink)
TN Pussy Man
tire shop is your best friend- they deal with this kind of thing all the time
HaHa
Old 08-03-2006, 12:02 PM   #8 (permalink)
Registered User
Would tire shops have my key to remove other locks on remaining three tires ?
Old 08-03-2006, 05:50 PM   #9 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
no- they would rip them off with a generic removal tool or socket and you wouldn't be able to use them again.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 08-04-2006, 12:56 PM   #10 (permalink)
Registered User
If I had to hammer a socket over this damaged locknut, what size would I choose ?
Old 08-04-2006, 02:57 PM   #11 (permalink)
TN Pussy Man
we can't answer that for you
you usually use one that's one size smaller than the actual size
HaHa
Old 08-17-2006, 09:47 AM   #12 (permalink)
Registered User
Bought a Nut Remover set from Sears. Does anyone know which remover nut # I require for my rounded locknut ? The package says to use #13 for 19mm and I measured one of the other good locknuts I have to be 20mm.
Old 08-19-2006, 09:37 AM   #13 (permalink)
View solidg's Photo Gallery
quick messing around
get a drill with a metal cutting bit
drill that lug nut off
tap out the stud
put in a new stud
call it a day
solidg is offline   Reply With Quote
Getting alarm to chirp procedure - here it is JJMARINE 2nd Generation (2005+) 27 07-13-2007 04:06 PM
Gen 5 steering wheel lock drunken_panda 5th & 6th Generation (2002-2006 & 2007-2011) 6 03-01-2006 12:30 PM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 01:17 AM
Wheel Lock flyhigh6 General Discussion 11 09-23-2004 12:38 PM
98 Corolla wheel bearing retainer nut size???? neil85AE86 Archived Corolla threads 0 12-03-2001 08:58 AM
