Help with Initial K Gauges - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2001, 01:15 PM   #1 (permalink)
View phat555's Photo Gallery
Hi, I need help with my Initial K Gauges with my 1992 Camry LE. I an planning on connecting the wires to a fuse but the thing is the indiglos are always on. I want to connect to the headlight fuse but there isn't any fuse for that? Does anyone have any ideas of any fuse I can connect it to so when I turn on my headlights it turns on and when I shut the headlights off it turns off? Thanks.
phat555 is offline   Reply With Quote
Old 12-24-2001, 03:01 PM   #2 (permalink)
View critikal's Photo Gallery
Try your parking light wire, its green and located right below the fuse box in your car, probably behind the change holder. Good luck
critikal is offline   Reply With Quote
Old 12-24-2001, 03:04 PM   #3 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
i dont think there is a fuse for it because its all connected in the accessories ... what i think u should do is wire it with ur headlight switch.. i havent actually installed one yet but i am planning to get one ... if u have a haynes repair manual it would greatly help you in tapping the wire in the right place that way u can have it off in the day and on at night... good luck
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 12-25-2001, 03:50 PM   #4 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Tap into the first green wire from the big connector that goes into the cluster. Basically, when you turn on your parking lights, your indiglos will turn on. Many of us in TO have it setup that way...I find that the best way...the indiglos use very little power, so don't worry about blowing a fuse or anything like that.
Silver Streak is offline   Reply With Quote
Anyone interested in Custom Gauges 92-96 Gen 3's?? Keyser Soze 3rd & 4th Generation (1992–1996 & 1997–2001) 49 06-23-2002 12:27 AM
Initial K indiglo gauges 92-96 camry mrbacardi 3rd & 4th Generation (1992–1996 & 1997–2001) 42 05-08-2002 10:09 PM
custom indiglo/reverse indglo gauges J SWO Camry & Solara Lounge 3 02-03-2002 04:11 PM
Where can I find Initial K Indiglo Gauges For my 92 camry §oUnd Killa 3rd & 4th Generation (1992–1996 & 1997–2001) 2 11-23-2001 03:59 AM
