2AZ-FE Oil Pressure Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2006, 05:32 AM   #1 (permalink)
Downunder Tarago Owner
chrisnstell's Avatar
View chrisnstell's Photo Gallery
I have a 2AZ-FE motor in my 2002 Tarago but I believe it is the same motor that his used in the Camrys.
A few days ago, the oil warning light came on whilst I was driving, followed by a noticeable valve lifter noise. I stopped the van and checked the oil which was down by about a litre.
I re-strated the car and the light went out and the noise was gone. I drove the car home and topped up the oil. I took the car for a drive of about 6 miles and the light came back on and again, a lifter noise. I nursed the car home and let it sit overnight, then started the car and had it running in my drive way for 40 minutes, the light stayed off until I drove the car onto the street. I don't think it is just a faulty oil light switch because of the accompanying lifter noise.
Today I removed the oil pan and inspected the oil pick-up. It had some flakes on it but they did not appear to be metal so I don't think they are from bearings.
There was no evidence of sludge in the oil pan or on the pick-up. I dont know the full service history of the car so it may have not been good before I bought it secondhand. It has done 140,000 kilometres.
Has anyone had a similar experience that may be able to shed light on what is happening?
chrisnstell is offline   Reply With Quote
Old 08-07-2006, 01:49 PM   #2 (permalink)
View toyomoho's Photo Gallery
Install an oil pressure gage. Oil pressure should be 4.3psi or more at idle, 36-78psi at 3K rpm. Could be a problem with the oil pump pressure bypass valve. Worn bearings will result in lower oil pressure. The oil light comes on at around 4psi. Have you recently been using a different brand/type of oil filter? Check for sludge by pulling off the valve cover.
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
86 mr2, low oil pressure? YOU VIEW NOW!! mr2poweraw11 MR2 Forum 5 08-21-2005 01:05 PM
Oil Leak in 93 Camry LE 3VZ-FE V6 Front Valve Cover or Oil Pressure Switch? Xander 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-09-2005 05:27 PM
