2002 camry v6 se starter problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2006, 03:37 PM   #1 (permalink)
View ribeater's Photo Gallery
I/m wondering if anyone has encountered this problem and can offer some advice...my camry suddenly won't start...it has 110,000kms and i have had no prior problems. the battery works fine, power to everything but when i turn the key i just get a clicking sound and the dashboard warning lights flash.
if anyone has any insight, much appreciated
mike
ribeater is offline   Reply With Quote
Old 08-13-2006, 10:32 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
sounds like a starter solenoid
either you can just replace the solenoid, or you can just pick up a rebuilt starter for pretty cheap
as a temporary fix, the starter will usually work if you tap it with a hammer
HaHa
Old 08-14-2006, 06:10 PM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
you may also want to check your connections at the starter. check both the power and ground. go from there. also, for shits and grins, use a voltmeter and check the voltage in the battery and make sure the cables are good and tight.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-16-2006, 12:23 PM   #4 (permalink)
Gameroom cash: $304355
If you are hearing 1 click, then the problem is the starter's solenoid internal contacts. If you are hearing multiple rapid clicks, then the problem is with the battery, corrosion on the battery post/terminal connections or the conections at the starter, or the cables leading to the starter and ground itself.
Mike
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
Can I Retrofit 2005 Camry SE Headlights to a 2002 Camry LE??? LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 20 07-31-2006 10:54 PM
Electrical System Problem 2002 Camry SE dawgilama 5th & 6th Generation (2002-2006 & 2007-2011) 1 09-20-2004 08:43 AM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
