94 camry ac - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2006, 07:57 AM   #1 (permalink)
View cantstop's Photo Gallery
94 camry ac
i bought a 4cyl camry with out working ac.sometime a charge works ;it didn't(ac compressor wont come on,light is on dashboard.want to test if compressor is shot.usually you can short the pressure switch on the drier.i unpluged this,which causes both fans to blow full spreed,and i notice 4 wires,not the two that are seen on older cars,anyone know which two energize the compressor circuit?
cantstop is offline   Reply With Quote
Old 08-14-2006, 05:12 PM   #2 (permalink)
View toyomoho's Photo Gallery
The compressor is engaged by a magnetic clutch. In most cases you should see one wire running from the compressor harness plug to the front clutch area. This is the wire that needs to be energized. One wire from the plug should go to ground. The other two wires go to the speed sensor. This may be underneath the compressor, somewhere in the middle of the case. If you look, you should be able to follow the four wires to their source.
Old 08-15-2006, 11:17 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the lite in the button will blink and disable the compressor if it energized and the speed sensor sees that it is stopped, its a safety feature to keep a locked up compressor from smoking the belt off it, the sensor on the dryer is for the fans and hi pressure compressor cut off, i have a gen2 and there is no lo side switch
just test drove 94 camry bowlofturtle 3rd & 4th Generation (1992–1996 & 1997–2001) 12 09-17-2007 06:02 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
93 camry and 94 engine adroe3 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-02-2005 06:31 PM
94 camry xle jojopell 3rd & 4th Generation (1992–1996 & 1997–2001) 1 10-09-2004 02:43 PM
