Strange Throttle behavior - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2003, 07:40 AM   #1 (permalink)
View dubell's Photo Gallery
Unhappy Strange Throttle behavior
I have been having the strangest problem with my camry. When it get's warm, it has been stalling on me, and sometimes won't restart until it is cold. I put a new distributor, ecm (computer), and adjusted the throttle position sensor. That helped a bit, but not when it warms up, the throttle goes up to about 3,000 rpm. For example, when I started it up after it was already warm, the tachometer went up to 3,000 rpm and then back down to 850. Any ideas on what to do next?
dubell is offline   Reply With Quote
Old 04-08-2003, 11:35 AM   #2 (permalink)
Dacatz's Avatar
View Dacatz's Photo Gallery
i will recommend u to bring it back to the dealer and get it fix
Current
92 Previa rwd (Captain seat, dual roof, cool box)95 Previa s/c rwd (Captain seat, dual roof)
Sold
93 Previa rwd Captain seat (parents took it),92 Previa (base model),92 Previa rwd (Captain seat, dual roof),91 Previa rwd (rip),98 240sx rwd,91 Corolla wagon fwd,86 Ae86 rwd
Dacatz is offline   Reply With Quote
Old 04-09-2003, 12:24 AM   #3 (permalink)
V8 POWERRRR
View skperformance's Photo Gallery
more info year and engine?
clean your throttle body first though
R.I.P. Dad, Shabeer Khan 11/09/06
Toronto area Lexus Owners Meet My 98 LS My 94 ES
skperformance is offline   Reply With Quote
Old 04-09-2003, 08:29 AM   #4 (permalink)
View dubele's Photo Gallery
1995 4 cylinder camry. I did clean the throttle plate as well.
Thanks
dubele is offline   Reply With Quote
Old 04-09-2003, 08:57 AM   #5 (permalink)
View rpj1984's Photo Gallery
Maybe thermostat
rpj1984 is offline   Reply With Quote
Old 04-09-2003, 06:15 PM   #6 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
Re: Strange Throttle behavior
had the same problem ... its your internal coil . its inside the distributor ... IT needs to be replaced...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 04-09-2003, 08:01 PM   #7 (permalink)
I put a whole distributor in which includes a coil. Did you experience you idle going up and down?
Old 04-09-2003, 10:19 PM   #8 (permalink)
Dacatz's Avatar
have u try idler or O2 sensor?
Current
Sold
Old 04-10-2003, 12:21 AM   #9 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
yes...
Try checking the connection into your thermostat...
MySpace:
Old 04-10-2003, 07:18 AM   #10 (permalink)
ok, I think the next thing I am going to try is the idle control. I called my local toyota dealer and they also mentioned that. He also mentioned the egr valve. I'll check out the O2 sensor and connection to the thermostat.
Thanks guys,
Doug
Old 04-10-2003, 09:22 AM   #11 (permalink)
V8 POWERRRR
http://yotarepair.com/index.html
see if you can find an answer here
the thing is the car is in open loop until warm
meaning the computer disregards the readings from most sensors
like o2 sensor and some others until warm
is it possible that it is the o2 is bad but
probably not as it would still run with a defective one
just very rich for fuel ratio , so it wouldn't stall
egr also probably not it would stumble have a good amount of power loss,plus they usually stick open or closed but can't make an engine stall,idle rought though yes,as it only recurculates exhuast air back into the combustion chamber to decrease emmisions of unburnt gas
thermostat also can't shut off a car only tell the computer the wrong temp meaning it will either run open loop still or take into account the rest of the sensors and tell you on a gauge also turn the fan on to cool it
it really does sound like an ignition problem with a resistor that is going open when hot from the additional resistance
when you try and start the car after it dies does it actually start but dies as soon as you let go of the key?
as some ignitions have this bypass feature for starting with increased output but goes to regualr when started ,so if there is a problem with that cuircut it dies over and over again
godd luck let us know what you find
Old 04-10-2003, 09:23 AM   #12 (permalink)
V8 POWERRRR
one more thing can you tell if the car is about to stall ?
also if you give it gas does it keep the car from shutting down?
Old 04-10-2003, 09:49 AM   #13 (permalink)
When it does stall, it SOEMTIMES does not want to restart. After several attempts, it does finally start, but I usually do have to pump the gas to keep it alive. Once I get going, it behaves fine. Also, when I approach a stop sign and I notice it is about to stall, I pump the gas and this keeps it from stalling.
Remember, I did put in a new distributor. It seems like something is telling the car to not idle correctly.
Thanks
Old 04-10-2003, 11:20 AM   #14 (permalink)
V8 POWERRRR
try cleanning the throttle plate again
or see if someone can help you do it as it can be a bit weird besides just spraying the can down the inlet
the screw i thinnk is made in the intake and is not supposed to be manually changed
it is controlled by the ecu
and vacum hoses
but if the idle vacum line goes off it causes the bladder in the idle controller to rev the engine to about 3000 by opening the throttle when no vacum is present incase of this problem so youi can still drive home to get fixed
also if you start the car let it warm up without driving it will the car stall
even though it is still in the driveway?
Old 04-10-2003, 11:26 AM   #15 (permalink)
It did stall on me once in the driveway without driving it.
Thanks
P.S. - I think what I am going to do is take it to a dealer and see what they find out.
