How do i turn off the airbag light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2003, 10:07 PM   #1 (permalink)
BTL
View BTL's Photo Gallery
Ever sense i installed my reverse gauges my airbaglight has been on anyone know how to turn it off?
Thanks
BTL is offline   Reply With Quote
Old 04-08-2003, 10:34 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
do a search under keyword "airbag", username "Silver Streak"
Phi is offline   Reply With Quote
Old 04-08-2003, 10:53 PM   #3 (permalink)
BTL
yeah i did the link that i found no longer works
http://gibsonfamily.dhs.org/camry/95...light/rs49.jpg
Old 04-08-2003, 11:36 PM   #4 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
try harder man
Old 04-10-2003, 08:58 AM   #5 (permalink)
Bring it !
View WickedGen3's Photo Gallery
well depends what you want to do.. do you want to diable the light so that it won't come on ever again or do you want to fix your airbag.. if you want to disable your airbag light there is a fuse that you take that can prevent the light from coming on even when you turn on your car.. the fuse is behind the coin holder .. on the lower left hand corner next to the steering wheel.. just open it and look behind the coin holder and you will see the fuse for it.. just pluck it out and problem solved.. thats what i did.. but if you want to fix your airbag which i'm saving money for.. then you go to either the dealer and have them reset your airbag or go to some other place that does it.. for way less then the dealer.... i think i got a quote.. it should be no more than a 100 $ US.. but if it costs more then that i suggest you go to the dealer.. lol.. hope that helps and i wish you luck..
Lates
Wicked Gen 3
WickedGen3 is offline   Reply With Quote
Old 04-10-2003, 09:09 AM   #6 (permalink)
View DIRTBIKEZ's Photo Gallery
Dont mask an airbag problem, you are much better off fixing it the right way, especially if its only $100.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 04-11-2003, 10:02 PM   #7 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
I removed the pic from my site, but here it is again.
Silver Streak is offline   Reply With Quote
