99 camry leaking water - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2006, 09:13 PM   #1 (permalink)
View userid's Photo Gallery
Like the title says, my camry is leaking water. From what i can tell, it's a bit behind the oil tank, I can take picture of it and post up. I also just got my timing belt and water pump change. Any suggestion?
userid is offline   Reply With Quote
Old 08-23-2006, 09:55 PM   #2 (permalink)
View trickyazn's Photo Gallery
have you been using the a/c while idling?
trickyazn is offline   Reply With Quote
Old 08-23-2006, 11:32 PM   #3 (permalink)
View Ken4's Photo Gallery
What do you mean by 'oil tank'? You mean fuel tank or oil sump?
Ken4 is offline   Reply With Quote
Old 08-24-2006, 01:28 AM   #4 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Think he means oil pan. And yes, if it's just water then it's probably the drain for the AC.
Dave's is offline   Reply With Quote
Old 08-24-2006, 04:43 AM   #5 (permalink)
dont recall using the a/c, i live in seattle it's relatively cool these past few weeks. and yea i mean the oil pan
Old 08-24-2006, 09:47 AM   #6 (permalink)
Gameroom cash: $304355
Is it clear water, or is there some kind of color to it? Remember, water from the a/c drain will be clear; other fluids will be pink, red, green, yellow or even dark brown. The color will help us determine what is leaking.
Mike
Old 08-25-2006, 07:08 PM   #7 (permalink)
it's clear, so even if i dont use the a/c it still draining water?
Old 08-25-2006, 08:17 PM   #8 (permalink)
View southpawz's Photo Gallery
If you have used the defrost on the cold setting it will kick the ac compressor in too....so maybe this could be the deal...not sure but figured it was worth a shot
southpawz is offline   Reply With Quote
98' Camry Water Pump repair cost? mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-08-2008 06:11 PM
02 Camry Water Pump Replacement rkelachim 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 02:08 AM
noob w/ 99 camry le 4cycl 3 speed w/ o/d a/t Gachinto Camry & Solara Lounge 5 12-04-2004 06:33 PM
mod a 99 camry le ? Gachinto General Discussion 2 12-02-2004 07:40 PM
Question about 99 Camry (Toyota newb) redly1 Camry & Solara Lounge 4 06-10-2003 02:44 PM
