On your Camry, the sensors are only looking at the front converter. You can tell by the positioning of the sensors in the exhaust tract. One sensor is in the top of the exhaust manifold (before converter, measures air fuel ratio), second sensor is just after the front cat which monitors efficiency. The rear cat is just along for the ride and usually get hollowed out on my cars. Assuming you have a 4 cyl, you will need to replace the cat/manifold to get rid of the code.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
