How to aim fog light? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2006, 01:10 PM   #1 (permalink)
View ben805's Photo Gallery
Gen5 How to aim fog light?
I have a 2005 V6 SE, is it possible to adjust the fog light slightly higher so it can project the light a little bit further? if so....how?
ben805 is offline   Reply With Quote
Old 09-01-2006, 07:17 PM   #2 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
either remove the engine splash guard on the side of the fog light you want to adjust, or remove enough bolts and clips for you to get a hand and a screwdriver/wrench up into the bumper to adjust the foglight. its very similiar to how your headlights are adjusted... and you might want to raise the vehicle to access things easier
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 07:40 AM
05 Fog Light retrofit Activator 2nd Generation (2005+) 18 01-26-2007 09:04 PM
what do u guys think? Geius Maniacal 89-95 Toyota Pickup/Hilux 33 05-26-2006 02:45 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
Aftermarket FOG LIGHT SWITCH WIRING PROBLEM...2002 Tundra SR5 garzee13 1st Generation (2000–2006) 3 11-24-2005 05:58 AM
