Wire color question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2006, 12:59 AM   #1 (permalink)
PBM
Boob
View PBM's Photo Gallery
Wire color question
Does toyota use the same wiring color scheme throughout the generations for camries? (if not for all of their vehicles)
i have a wiring guide listing of colors and what's in each wire/what it's for, but it's for an older camry and was wondering if it would still be accurate on newer ones.
PBM is offline   Reply With Quote
Old 09-02-2006, 01:41 AM   #2 (permalink)
View toyomoho's Photo Gallery
TN has on-line wiring diagrams for 1987 to 2007 Camry. The electrical design between generations of cars is close. One model-wiring diagram does help with another. But before using an earlier or later diagram it would be best to confirm some know wires colors and locations are the same. Toyota can and does change things.
Old 09-02-2006, 12:18 PM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $261890
View Doctor J's Photo Gallery
Toyota uses several specific wire colors that are the same on all years:
  • white wire, black tracer for ground
  • blue - hot when ignition switch is on
  • white or white with red tracer - hot at all times
Doctor J is offline   Reply With Quote
Old 09-02-2006, 09:47 PM   #4 (permalink)
PBM
Boob
thank you very much for that
Old 09-03-2006, 02:50 AM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
HaHa
Old 09-03-2006, 07:46 PM   #6 (permalink)
PBM
Boob
i'm trying to find an always-hot 12v to tap into within the bundles of wires that are laid along the driver's side. i don't think i saw any white with red tracers
Old 09-04-2006, 03:36 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Ignition harness at the bottom of the steering column.
White or white/red (white with red stripe).
"Skoolin' the unlearned!"
Old 09-04-2006, 08:05 AM   #8 (permalink)
PBM
Boob
all i saw was red with white stripe, or else i'm looking at the wrong harness. regardless, none of those wires seemed to have any slack for me to work with.
this is for a gen 5.5 LE.
are there any always-hot 12v lines behind the console just in front of the shifter? there are bunches of cables that are just taped/wrapped off i'm assuming for features that my car didn't get, in the same bundle as the 12v cig plug harness is on.
Old 09-04-2006, 08:24 AM   #9 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Yea you can look for a white/red wire for 30A or a white wire for 5A both in the ignition harness.
http://www.xclusive.bz
Old 09-04-2006, 08:55 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
The ignition harness is hard to miss. 6 or so 10-12 awg. wires at the bottom of the steering column.
Get a DMM and probe the wires.
Old 09-04-2006, 09:10 AM   #11 (permalink)
PBM
Boob
yeah i put myself upside down in the driver's seat with my head in the well (cause the door has to be closed and i didn't wanna go through the hassle of taking off the panels to disconnect the door ground switch) and i saw the bigger wires. but i also saw a white w/ red stripe wire that was skinner on a harness to side of the ignition ones so i tried that but for some reason it's not working. voltimeter reading on that white w/red striped wire was pretty much 0
where would be a convenient spot to tap into the thick white w/red ignition cable? i'm having a really hard time getting enough slack to work with it but i could always go closer to the firewall i suppose and go hacking away at all that electrical wrap and looming.
i'm just wondering why that skinnier white w/red stripe wire wasn't getting any juice
Old 09-04-2006, 09:30 AM   #12 (permalink)
Grenaded piston
88 LE's Avatar
Don't assume that wire is constant +12V, just because its the same color as a wire in the ignition harness. That wire may be for something else, for what I don't know.
Did you probe the big wires in the ignition harness? White and white/red should be constant +12V.
And did you hookup the black probe on the meter to a good ground? Just because its metal, doesn't mean its grounded.
Is the meter set on the proper voltage range?
Anywhere along that wire is fine.
Old 09-04-2006, 09:36 AM   #13 (permalink)
PBM
Boob
yeah the meter was set to 20 for voltage and when i touched a good ground it would jump to 0.04 and go back to 0. that was for the skinny wire.
anyway, the thicker wire should be fine, i was trying to avoid using that one and find a constant source somewhere more convenient to work with but no luck with that i guess.
Old 09-04-2006, 10:27 AM   #14 (permalink)
PBM
Boob
i got it, thanks for the help guys.
still got some work to do but i'm too stressed out.
i'm trying to get cathodes to turn on when i press the unlock on my remote but all i got now are lights that turn on when the door is opened. grrrrrr.
Old 09-04-2006, 12:06 PM   #15 (permalink)
PBM
Boob
i can't seem to find these. care to point me to it?
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 07:40 AM
MSD Ignition luisitol Camry & Solara Lounge 23 03-15-2009 02:13 PM
Basic Amp Install Instructions Phi Audio, Video, and Security - Tech 11 04-06-2005 02:25 PM
extra battery 97avalonxls Audio, Video, and Security - Tech 9 09-20-2004 12:09 PM
Subwoofer Install? CamrySpeaksJL Audio, Video, and Security - Tech 17 02-07-2003 08:33 AM
