2002 Camry XLE Radio Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2006, 12:34 PM   #1 (permalink)
View mistermonday's Photo Gallery
Can anyone please tell me how to remove the radio unit from a 2002 Camry XLE. Can you remove the trim around it alone or do you first need to remove the AC module below it?
Thanks & Regards, MM
mistermonday is offline   Reply With Quote
Old 09-07-2006, 06:01 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
prey out the climate controls carefully, disconnect the connector there. remove the two 10mm bolts from the bottom of the radio bezel, pry out and remove. remove the two 10mm bolts that hold the radio in the car by way of the brackets. slide the radio out, disconnect the harness and remove the radio.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:43 AM
Question about my 2002 Camry XLE Aznguy82x 5th & 6th Generation (2002-2006 & 2007-2011) 2 12-27-2005 09:20 AM
Odd Question about my 2002 Camry XLE Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 3 10-13-2002 03:46 PM
