pcv valve grommet - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2006, 05:37 PM   #1 (permalink)
View funnysam's Photo Gallery
pcv valve grommet
Dear everyone on the board,
though it may sounds stupid, but I am experiencing a huge trouble right here.
Is there any special tool or easier way to take out the pcv grommet? i've been working with it for the past 2 hours...but had little luck..
i cut a portion of it off, used a plier, flat head screwdriver..but ya, it's still in there...
can anyone please help?
sam
funnysam is offline   Reply With Quote
Old 09-06-2006, 07:21 PM   #2 (permalink)
this is what i say >
v-cam's Avatar
View v-cam's Photo Gallery
PCV grommet or actual valve???
True car enthusiasts are open-minded to everyone's creation
v-cam is offline   Reply With Quote
Old 09-07-2006, 03:26 PM   #3 (permalink)
The grommet unfortunately...
shops' gonna charge me $75 for it..
1MZ-Fe engine..
help anyone?
Old 09-07-2006, 05:49 PM   #4 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
try a little oil. soak it a tad. the grommet dries out over the years and the heat of the engine doensnt help much either. it will be very brittle and will most likely break apart on you, so make sure you have a new one from toyota. just keep plugging away at it with the needlenose and a if you have a right angle pick tool use it. a flathead will work but you need to be careful not to damage the aluminum valve cover.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 11-21-2006, 09:18 PM   #5 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Lightbulb
I, too, had a really hard PCV grommet (my truck is in my signature).
I just waited until I had the valve cover off for the valve lash inspection. Then, I could really chip away at the hardened rubber w/ impunity and not fear that any particles would fall into the top end.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 12-02-2006, 03:58 PM   #6 (permalink)
Once upon a time...
View kbox's Photo Gallery
Guys,
I have around 400 of those grommets in stock. Drop me a line if you need any.
Jody Collicutt - [color=blue]'87SC J-Spec DLI AE92 - 246,246 kms and counting...
kbox Engineering www.kbox.ca
kbox is offline   Reply With Quote
V-6 Fuel Filter & PCV valve Lupine 3rd & 4th Generation (1992–1996 & 1997–2001) 9 08-17-2006 09:11 PM
my pcv valve snapped in half and is stuck jrinco11 Tercel, Paseo, Starlet, and Sera Forum 7 02-06-2006 09:56 AM
PCV valve is screwed up... I helped it.. 4EVERCooL 1st Generation (1995-1999) 3 11-14-2005 07:55 PM
4A-GE PCV valve? cunada23 Archived Corolla threads 21 04-07-2003 09:42 PM
