Here is an update on how my car is coming along;
Got it as a stock automatic and it was running high 17's in the 1/4 mile.
Swapped to 5 speed, lightened flywheel, underdrive pulley, intake, act clutch, sticky tires and it was good for high 16's .......
last night I took it to the track at Gateway International and my first pass on 6 pounds of boost netted me a 60 ft time of 2.56 (ouch!) and 15.5 @ 91.1 mph! Next I tried launching at a higher rpm and shifting into 4th since 3rd gear raps out right before the finish.... ouch 16.1 @89 mph.... Next I lowered tire pressure since first gear was having issues with traction and I just let third gear bounce off the rev limiter once or twice, This netted me my best run of the night.....
Not bad but I was a bit dissapointed. Mostly I suck at launching, a 2.437 60 foot is pretty bad but for every tenth of a second the 60 foot time drops, its a drop in two tenths off the ET. So if I can net a 2.25 or so I should be able to bring in a 14.9 second pass at a trap speed still in the low 90's. I am going back to the track again and raising boost back up to 9psi that I had been running for awhile. I ran 6 pounds at the track to get used to it first and I retuned while I was driving down to the track. So a better tune, 3 more psi, better launch, and new plugs and I hope to bring in a 14 second pass before the end of the season. (as temps keep dropping, the car pulls harder and harder too...) Oh and the other car was an 04 Civic 5 speed with headers, chip, intake, exhaust, clutch, and sticky tires. (beat him in a 4 door camry lol)
Here is how the car is looking lately;
Made a heat shield out of some scrap sheet metal and painted it duplicolor aluminum, really cut down on radiant heat quite a bit. I also used the old short ram intake to extend the filter off the turbo compressor and into a cooler area. I want to make an aluminum shield to isolate the filter and have it draw air from the fender eventually.
I added a Greddy full auto turbo timer and installed it where the stock clock used to be. Lights up blue at night and looks pretty cool.
I got a 11.5 inch steering wheel and a momo hub off a friend for $50 so what the heck.
Stay tuned I will keep trying to break 14 second barrier and post up when I do, then I need a 3sgte to go for 12 second barrier! I want to see how far a 4th gen can be pushed...
