just replaced struts.. need alignment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2006, 03:56 PM   #1 (permalink)
View crasher's Photo Gallery
hi ,
i just replaced my front struts and upper mounts ( kyb ) do i need to get a front end alignment ...the tire store in town said i do >.>>.... any thoughts thanks eric oh its a 1999 le camry 4 cyl. 105 k sure did make a huge difference after replacing those parts bye..
crasher is offline   Reply With Quote
Old 09-10-2006, 07:01 PM   #2 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Yeah, whenever you replace struts or springs, you'll most likely need an alignment. I would recommend getting the 4-wheel alignment, it's usually only a few dollars more expensive.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 09-11-2006, 11:45 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140895
probably should so you dont kill your tires or have the car pull when youre on the highway. though im still waiting to do so with one of my cars after replacing the suspension, and its been almost 2 years now.
Old 09-11-2006, 11:58 AM   #4 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
why would you need an alignment? i've replaced a ton of struts and never got any alignment and all was fine? it doesnt change the alignment, so why would you do an alignment? please correct me if im wrong and explain how it affects the alignment.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-11-2006, 08:32 PM   #5 (permalink)
View Ken4's Photo Gallery
I agree. Only toe-in is adjustable, camry castor and camber are not adjustable. When you replace camry struts, the tie-rods are not affected. Wheel alignment is not necessary. If you look at the camry top strut mount, it is fixed, unlike some european cars where they are adjustable. The bottom of the strut that attaches to the hub axle is also fixed with 2 bolts. Unless of course you replaced these 2 bolts with aftermarket camber adjustable bolts, then you would need realignment.
Ken4 is offline   Reply With Quote
Old 09-11-2006, 09:28 PM   #6 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
Yes you need an alignment. Just because the steering wheel is straight does not mean it is in alignment. When i lowered my car, my steering wheel remained straight and when i hit the alignment rack, it was ALL OUT OF WHACK!! the alignment was way off! Everytime i do suspension work i do an alignment, i even did an alignment after my big brake kit .
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 09-12-2006, 02:25 AM   #7 (permalink)
That's bcos when you lower your car, it affects camber. You need aftermarket camber adjustable bolts to bring it back to spec. Common sense.
Old 09-12-2006, 07:26 PM   #8 (permalink)
The Greek....
GrkBallaG's Avatar
read my post buddy, EVERYTHING WAS OUT OF WHACK! and i have camber plates, so blah!
The SLAMry.....
Old 09-12-2006, 08:37 PM   #9 (permalink)
Original threadstarter did not lower his car. And he does not mention he has aftermarket strut adjustable camber plates or bolts. So only thing adjustable is toe-in. Please explain to me why toe-in needs to be readjusted. Removing and reinstalling strut does not involve touching the steering tie-rods.
http://www.cruzinonchrome.com/html/camber_kits.html
Old 09-12-2006, 09:07 PM   #10 (permalink)
The Greek....
GrkBallaG's Avatar
The SLAMry.....
replace or not to replace struts good_old_geo Archived Corolla threads 6 09-10-2005 09:41 PM
Dealer Coupon for struts..........worth it?????????????? redgtxdi Camry & Solara Lounge 4 09-03-2005 10:11 PM
97 LE rear struts = new alignment? natman 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-03-2005 02:50 PM
Gen 4 struts LWF 3rd & 4th Generation (1992–1996 & 1997–2001) 2 04-22-2004 03:04 PM
new struts, old problems Jefferson Camry & Solara Lounge 11 10-07-2003 04:59 PM
