You should get back to basics. What you are describing, missing on acceleration, sounds like an ignition system problem. When the system is under load is when ignition system problems seem to surface. Is this problem worse in wet/damp weather? Start by checking the plug wires through the distributor cap with a DVM for resistance. There should be a spec somewhere in any manual. If you can't find a spec, an old rule of theumb was approximately 7,000 - 10,000 ohms of resistance per foot of wire. Chances are you will find 1 or 2 you can't get any reading on. This means there is a break internally in that wire and it needs to be replaced. Best to replace the whole set.
If you don't find any problems with the plug wires, then I would check the distributor cap, rotor for signs of tracking. Next I would pull and replace the plugs themselves. They are cheap enough to just replace. They should be replaced every 30,000 miles on a generation 1 with the 2SE engine. If all this checks out OK, I would check the coil inside the distributor. They were a known trouble area on early generation Camrys. Again you will need a DVM and the specs from any manual to do this. You may also visually inspect the coil for any signs of hairline cracking. This was the known trouble spot.
Mike
