Have CEL 441 and 446 for the longest time and I have decided that I want to get rid of it. Toyota wanted to charge me $200 for labor.
Did lots of research from the recall about the VSV for 96-98 camry, etc.
Question:
1) How hard is it to get to and replace VSV and Charcoal Canister?
I am unable to find info / pics and Haynes manual was not too clear
2) What is the skill set required? I am not a mechanic but I m handy with tools. I have a decent set of tools (150pc).
3) Should i go with after market parts (Autozone) or Toyota parts
4) Anybody know where can i get the part # for VSV and Charcoal Canister?
Looked and look but i must be looking at the wrong area as i m not able to find it
A. Diagnostics for PO441:
1. Remove Vacuum Hoses between EVAP VSV and Charcoal Canister and discard.
2. If there is a metal vapor pipe between EVAP VSV and Charcoal Canister, clean inside of vapor
pipe
3. Replace EVAP VSV and Charcoal Canister assembly with new parts.
4. Install new vacuum hoses between EVAP VSV and Charcoal Canister.
B. Diagnostics for P0446:
1. Inspect vacuum hoses and pipes between EVAP (Purge) VSV and Charcoal Canister for leaks.
2. Replace Vapor Pressure VSV and Canister.
NOTE :When performing diagnostics for an occurrence of a MIL "ON" condition, Diagnostic
Trouble Code (DTC) P0441 may be result of debris in Evaporative Emission Control System. This
may cause blockage of a vapor line, or a stuck VSV, as described in troubleshooting area of Repair
Manual.
Question:
I am unable to find info / pics and Haynes manual was not too clear-PRETTY EASY. THEY SHOULD BE ON THE LEFT SIDE OF THE ENGINE BAY NEAR THE TRANS.
2) What is the skill set required? I am not a mechanic but I m handy with tools. I have a decent set of tools (150pc).-THAT SHOULD BE FINE.
3) Should i go with after market parts (Autozone) or Toyota parts-DEFINATLY TOYOTA PARTS.
Looked and look but i must be looking at the wrong area as i m not able to find it-GO TO THE DEALER AND TELL THEM WHAT YOU NEED. THEY HAVE THE EPC AND IF THEY HAVE A GOOD COUNTER PERSON, YOU SHOULD BE GOOD. IF NOT, LET ME KNOW AND I'LL GET YOU THE PART NUMBERS AND COST.
For service data, check the TN link to on-line service manuals in Camry General Posts. These may not be exactly the same year as yours, but close enough. For parts, some web based dealers sell Genuine Toyota at a discount.
I had this exact problem too. My suggestion it replace your gas cap gasket first. If thats not is the replace the charcoal canister. I ended up buying the charcoal canister and never used it cause it was my gas cap. The dealership sells the canister for around 300 bucks. Ill sell it to you for 190 plus whatever the shipping is. Its never been used and still in the original box.
I got the same code but then it went away after a while. It was my gas cap. As far as I know that vsv part of the charcoal canister. Thats why I bought a new canister because it came with all the valves. The dealership didnt mention that I could buy the vsv on the canister seperate. Thats interesting for me to find out if they just failed to mention it so they could make a few more bucks.
I thought it is below the car by the engine and not the gas tank
Many thanks. I did read up on the PDF prior to posting. I did a couple of hrs research, etc
(still unable to find part #). I will go to the dealership tomorrow and get the parts - VSV and the tube/pipe that goes to the VSV cos they suggested changing it.
Thanks for all your input..
I think there are 3 vsvs altogether. You might be thinking of a different one.
I can think of only two vsv's.One up by the engine and one attached to the charcoal cansister. Make sure you replace the right one. You can test them to make sure they work. Its explained in the haynes manual how to do it.
Skewe- it depends on the year and engine. Some are back by the gas tank and some are in the engine bay.
I bought the whole chacoal canister cos i went to toyota today to get the ECAP VSV and they told me that it will be a custom order part for $60. Cannot return special order parts without restocking but can I can return in stock part (without restocking fee) if i cannot fix it so i will take a go at it.
The whole system part # is 77740-06170
Within the whole system, there are other components such as part # 89460-07030
90910-12264
Look at the image below, it is the square box and somebody pointed / marked it with red "fills with fuel".
took it to the dealership after spending 4 hrs crawling under the car %^%
I took all the pipes out, which was a pain cos some sealed itself to the joints.
I was unable to remove the canister cos it was too big and I was unable to slot it though the gap between the exhause and the axel.
If the was no contact/pressure on the tires, i could have slot it though cos the tires / axel would be facing down and provided a wider gap.
It took the dealership 1 hr to get it out.
63$ well spent
MIL ON DTC P0440, P0441 OR P0446Reference Number: EG013-03
Date Of Issue: September 29, 2003
TOYOTA: 2000 - 03 Avalon, Camry & Solara; 2001 - 03 Sienna
SECTION: Engine
INTRODUCTION
Under certain driving conditions, some 2000 - 2003 model year
Avalon, Camry (NAP only) and Solara vehicles, and some 2001 - 2003
model year Sienna vehicles may exhibit a M.I.L. "ON" with DTC(s) P0440, P0441 and/or P0446 stored due to an inoperative Canister Closed
Valve Vacuum Switching Valve (CCV VSV). The CCV assembly process has
been changed to correct this condition.APPLICABLE VEHICLES
2000 - 2003 model year Avalon and Camry (NAP only) vehicles
produced BEFORE the Production Change Effective VINs shown below.
2001 - 2003 model year Sienna vehicles.
2000 - 2003 model year Solara vehicles.
PRODUCTION CHANGE INFORMATION
ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
Model Engine Plant Production Change Effective VIN
Avalon ... 6 Cylinder ...... TMMK .................. 4T1BF28B*3U314261
Camry .... 4 Cylinder ... TMMK Line 1 .............. 4T1BE3#K*3U177289
Camry .... 4 Cylinder ... TMMK Line 2 .............. 4T1BE3#K*3U697270
Camry .... 6 Cylinder ... TMMK Line 1 .............. 4T1BF3#K*3U045051
Camry .... 6 Cylinder ... TMMK Line 2 .............. 4T1BF3#K*3U551469
WARRANTY INFORMATION
Op Code Description Time OFP T1 T2
178011 ... R & R Vacuum Switching
Valve (1MZ-FE, 2AZ-FE) ... 0.2 ... 90910-12199 ... 95 ... 83
Valve (5S-FE) ....... 0.4 ... 90910-12199 ... 95 ... 83
Applicable Warranty:
This repair is covered under the Toyota Federal Emissions
Warranty. This warranty is in effect for 36 months or 36,000 miles,
whichever occurs first, from the vehicle's in-service date.
For California, Massachusetts, Maine and Vermont, the Toyota
Federal Emissions Warranty is in effect for 36 months or 50,000 miles,
NOTE: Warranty application is limited to correction of a problem
__________________ It worked fine until I fixed it!
