2 camry Qs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2006, 01:09 PM   #1 (permalink)
View AmanO's Photo Gallery
4th Generation 2 camry Qs
My dimmer system is not workin. Can I just replace the panel with the dimmer dial (and mirror controlls) or is it something deeper. (if it is how expensive/extensive is it?)
I am getting water in my trunk in the driver side compartment under the mat (gen 4) I think the fuel line goes through there. Not just a little water either. Last time i looked there were goldfish in it.
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
Old 09-17-2006, 07:24 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
not sure about the water problem at all, but for hte dimmer question, the first thing you should do is just replace the dimmer and then see if that works- if not, then dig deeper
HaHa
Old 09-17-2006, 10:13 PM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
you should test to see if you are getting 12V switched power to the dimmer connector(key in acc position). if you are than the dimmer switch is bad. if not, your problem lies deeper. as for the water in your trunk, my guess would be that you have a bad trunk seal. the seal runs around the inside lip of the trunk and will shrink over time and harden, thus allowing water in. you may also have a bad antenna seal. no big deal because you have a tube that will drain the water under the car; unless the tube is cracked, broken or has come off and is leaking water into your trunk. check that as well. the fuel lines are under the car, not through your trunk.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-17-2006, 11:39 PM   #4 (permalink)
You mean the seal around the trunk lid?
My carpet is not whet but the board under it is. There is a puddle under that.
There is a tube running through that compartment.
Old 09-18-2006, 07:44 AM   #5 (permalink)
mazdaverx7's Avatar
correct on the tube. the tube is the drain for the antenna and the trunk ring. if the carpet isnt wet, inspect that tube. is it only wet when it rains? also, check for rust holes under there.
85 RX-7 GS 5spd
Old 10-25-2006, 12:01 AM   #6 (permalink)
Update: I was told that the tube is the drain for the moonroof.
Is this true? Where is the drainage hole under the car for this? (He said it was prolly clogged)
CAMRY WITH RIMS BIGGER THEN 18'S( 56k stay away ) lucanhookup Camry & Solara Lounge 69 03-14-2011 08:06 PM
FS: Misc Gen 4 Camry parts (engine/interior/exterior) got_trd Car Parts for Sale 41 08-01-2007 03:10 PM
What are you really missing with your Camry!!! smt_007 Camry & Solara Lounge 10 02-28-2006 11:01 PM
03 Camry motor, some Q's zenon 5th & 6th Generation (2002-2006 & 2007-2011) 3 04-03-2003 12:40 PM
2003 TOYOTA CAMRY XLE vs. 2003 HONDA ACCORD [NEW].. Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-15-2002 01:10 PM
