3VZ-FE Info - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2003, 10:48 AM   #1 (permalink)
View MK84's Photo Gallery
Smile 3VZ-FE Info
Hi guys, I just got myself a 3VZ-FE front clip for my MR2 And I have some questions.
1.What's the difference between the 3VZ and the 1MZ-FE? I know the 3VZ has an iron block and AFM.
2.Strong and weak points of both engines.
3.Specs of the 3VZ.
4.Info/guides for a fully-build 3VZ.
At the moment I'm planning to run the engine in NA form (built to Group N spec) and later I plan to turbocharge it. Any help would be much appreciated.
MK84 is offline   Reply With Quote
Old 04-22-2003, 04:28 PM   #2 (permalink)
confrontations of image
Structureboy's Avatar
View Structureboy's Photo Gallery
You're in luck, Sportcompactcar had an article on a 1mz-fe swap for an mr2. check out www.sportcompactcarweb.com . The article is fairly recent and should still be in the database with a bit of search.
straight from SCC:
3vzfe
weight: 469 lbs
has distributor ignition. closed-deck iron block. 10:1 compression ratio.
B/c the 3vzfe has iron block, it makes it a strong choice if you want to build a high-output turbo.
1mzfe: 401 lbs
compression ratio 10.4:1 aluminum head and block.
same bore as 3vz, but an additional 1.0mm stroke over 3vzfe. has sequential multi-port EFI, coil-on-plug distriburless ignition, variablae-plenum intake manifold, stainless steel tube headers, and trick girlde-reinforced main bearing caps.
More power on the 1mzfe than 3vzfe.
#39 Goalie for Baylor Ice Hockey Team
"life for him was an adventure, perilous indeed, but men are not made for safe havens."-Edith Hamilton
Visit:
www.emdef.org
|>Keep electronic music in our clubs<|
Structureboy is offline   Reply With Quote
Old 04-23-2003, 06:45 AM   #3 (permalink)
Thanx. I have a copy of SCC with the MR2 V6 swap. But it mainly covers the 1MZ-FE. Was hoping if anyone here can tell me more about the 3VZ.
