Indiglo Reverse Gauge Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2003, 03:24 PM   #1 (permalink)
View Mattx's Photo Gallery
I bought the reverse indiglo gauges off ebay and installed them this weekend everything went well had them working without a problem.
Until 24 hours later I am just driving and they decide to turn off on me I checked everything I could i hooked them up to my amp power and ground and still can't get them to work checked the fuse no luck.
If anyone knows what I can do to get them to work I would really appreciate it. Thanks in advance.
Mattx is offline   Reply With Quote
Old 04-22-2003, 07:45 PM   #2 (permalink)
Bring it !
View WickedGen3's Photo Gallery
could be the transformer.. but check the switch.. if they gave you the toggle switch like i got then probably one of the wires came loose.. it did for me and i couldnt' see the green side.. ( reverse guages ) .. and i just put the wire back in its place.. so that could be a start ! thats the most i can think of .. since it happen to me..
Wicked Gen 3
WickedGen3 is offline   Reply With Quote
Old 04-22-2003, 07:58 PM   #3 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
I'm definitely the undisputed champion of indiglo problems. I just fixed mine again this past weekend. My indiglos were blinking on and off....
I just redid the ground and power, and it now works fine. Why did you use the amp power and ground? How convenient was that? If anything, try using the cigarette lighter power, or even tapping into the power wire for the instrument cluster. Just pick a bolt behind the cluster for the ground.....
Silver Streak is offline   Reply With Quote
Old 04-22-2003, 10:58 PM   #4 (permalink)
I hooked it up to my amp wiring just to see if it would go on or not quickest way to test it.
But I was doing a search on the forum and I came across the site www.speedhut.com
and i found the new upgraded controller
High Power 2 color inverter upgrade
so I ordered that it should be here by friday or saturday lets see how this does.
Old 04-23-2003, 12:30 AM   #5 (permalink)
rayray's Avatar
View rayray's Photo Gallery
i had my gauges go out on me last year... but just the blue option... the green worked fine. found out that one of the wires on the back of the switch got disconnected. i had to solder that biatch back on... it wasn't easy.
you should check all wiring and connections. but i guess it's too late as you already ordered another transformer.
-rayray
rayray is offline   Reply With Quote
Old 04-23-2003, 12:34 AM   #6 (permalink)
I tried everything I could had it apart for 2 days tried different power connections checked everywire to make sure nothing was wrong.
We'll see what happens when the new invertor comes in.
Old 04-26-2003, 11:06 AM   #7 (permalink)
Blackbob21's Avatar
View Blackbob21's Photo Gallery
I had that exact issue with my reverse glo gauges. The only thing I did to fix it was make sure all the connections between the gauges were tight. If one of 'em is loose, they all go down. Just take 'em all apart and attach each one to a different connection.
-Bob
'97 Camry LE :: "Still not fast, but now it's glamourous!"
'93 Camry LE :: "It wasn't fast, but it was mine." R.I.P.
"In the end, Love is all that mattered."
Blackbob21 is offline   Reply With Quote
Old 04-26-2003, 02:02 PM   #8 (permalink)
View warlock's Photo Gallery
i had the same problem and it was the inverter.i found the inverter but i also found other gages i like and got them.no probs,so far
warlock is offline   Reply With Quote
Old 04-26-2003, 08:17 PM   #9 (permalink)
I received the new high power upgrade inverter in yesterday it took about 10 mins to put in and worked perfectly! It seems a lot brighter then the other inverter and also it doesn't hesitate when I change colors now.
Old 08-27-2003, 09:56 AM   #10 (permalink)
Un-Official TN dude
View TypeZer0's Photo Gallery
does the high power inverter work with any brand indiglo gauges?
TypeZer0 is offline   Reply With Quote
Old 08-27-2003, 11:17 AM   #11 (permalink)
I believe so. It was working great for a while then all of a sudden I am receiving a high pitched sound when it is in blue color mode as soon as I change it to green the noise stops.
Old 09-06-2003, 08:53 PM   #12 (permalink)
Un-Official TN dude
got a set of reverse gauges and had them installed today. it was working great so me and my friend went out. night came so it was time to show off my gauges in all its glory. worked great for like 20 minutes and in the middle of hte highway, it went out. 20 minutes later i get home after i dropped off my friend and i turned the parking lights on/off (powered it through the instruments power) adn i found taht they weren't off, just very dim.switching between blue and green did nothing and the dimmer switch only made it dimmer. was it smart to leave teh switch all the way at max? did the inverter overheat? if it overheated, should i stick a heatsink on it with some arctic silver epoxy? i'm letting it cool off for now, i mgiht go back and check if i don't fall asleep
