help! how to remove high pressure switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2006, 05:19 PM   #1 (permalink)
View finngal's Photo Gallery
Question help! how to remove high pressure switch
I have a 1998 V6 Toyota Camry. Air conditioning won't hold a charge - there is a leak right below the high pressure switch, above the nut. I was told there is an O-ring below the switch - does this maybe need to replaced for a buck fifty? Does anyone have experience with this? The nut won't budge - how can I get the switch off (without taking it to the dealer who wants to charge 240 bucks when the switch costs only $43!!!)?
finngal is offline   Reply With Quote
Old 09-28-2006, 11:09 PM   #2 (permalink)
View toyomoho's Photo Gallery
Toyota states to put a wrench on the body holding the sensor to prevent damage. Use another wrench on the sensor. No other special requirements were mentioned. Keep in mind the A/C system needs to be discharged if the valve is changed. If not, the Freon will come of the hole the sensor screws in to.
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
4af oil pressure switch location? freakinbox Archived Corolla threads 2 04-05-2006 04:46 PM
85 Celica GTS Fuel Pressure Problem Denis Celica Forum 6 03-16-2006 08:11 PM
Fan switch problems, only HIGH works WASABI Celica Forum 3 07-29-2003 01:52 PM
High pressure oil caps TRD 4Runner Off Topic 12 12-06-2001 09:16 PM
