Fused Iridium + Platinum Spark plugs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2006, 03:14 PM   #1 (permalink)
DO RE MI
View Blade Of Heaven's Photo Gallery
4th Generation Fused Iridium + Platinum Spark plugs?
Hey everyone,
I was thinking of getting new sparkplugs for my 2000 Camry and did some research on all the plugs availible. I then came upon an interesting spark plug by Bosch that just came out called the Platinum Ir Fusion. Apparently it fuses the center electrode with both Platinum and Iridium. Plus it uses 4 yttrium enhanced grounds (supposedly it's some kind of material used mostly in superconductor applications). Those of you with spark plug expertise... wanna comment on this. Would such a configuration be any good at all, or is it all hype? Here's the link you can check out.
http://www.boschautoparts.com/Produc...Plugs/IrFusion
If anyones tried em out let me know!!
Sincerely,
Isaac Liao
Blade Of Heaven is offline   Reply With Quote
Old 10-03-2006, 03:57 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
I doubt you'll find someone willing. When you say a word like "Bosch" around someone owning a car equipped with Denso ignition coil<s>. They generally shudder.
Single electrode NGK, or Denso plugs. They don't just work. They work very, very well.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 12-07-2006, 07:26 PM   #3 (permalink)
View bigdaddyooo's Photo Gallery
Agreed
After battling what seemed like a plug wire problem (4 sets in 6 months), I searched the forums here and found that BOSCH PLAT plugs do NOT work in these 2.2's. Every few thousand miles it will start to misfire with P0300 and P03XXX codes. Read here that if you switch to NGK or Denso plugs your problem will go away. SOB, I bought the Denso iridiums and the engine hasn't not misfired whatsoever since. BOSCH and TOYOTA do NOT mix........
bigdaddyooo is offline   Reply With Quote
Old 12-17-2006, 03:23 PM   #4 (permalink)
View hot_rod_bob's Photo Gallery
Lightbulb bosch fusion are not real Iridium
I work in a automotive lab and did a little research on the Bosch "Fusion" plug when it 1st came out. It is called Iridium enhansed for a reason. It really is a Platinium plug with a small amount of Iridium, only 20% Iridium and the rest is Platinium. In comparrision the Denso Iridium plug is over 90% Iridium with a special Rhodium content they have the patent on. The Rhodium provides a better electrical conductivity. The Bosch Fusion has a much lower melting point, about 450C lower the the Denso which defeats the purpose of using an expensive Iridium plug. Additionally the Denso plug is the only plug who uses a .4mm center electrode remember the smaller the center electrode the better the spark, without Iridium the small center electrode would normally melt. The Bosch plug is a bunch of marketing hype. After I did this research (for a automotive firm) I use Denso Iridium Power plugs in everything I own and they really make a difference. Even on my old motorcycle they made the idle smoother which was always giving me problems I never thoght a plug could make such a difference.
hot_rod_bob is offline   Reply With Quote
The Following User Says Thank You to hot_rod_bob For This Useful Post:
CT_highlander (03-23-2012)
Old 03-23-2012, 09:40 AM   #5 (permalink)
Official US Consumer
CT_highlander's Avatar
View CT_highlander's Photo Gallery
USA Do you notice better mileage/performance?
I have 75k miles on my 2006 Highlander. I'm wondering if replacing the plugs now would give a little better MPG and performance.
The manual says to replace at 100k.
What do you think?
2006 Highlander LTD 3.3 V6 with tow package, bought new.
CT_highlander is offline   Reply With Quote
Old 03-23-2012, 07:09 PM   #6 (permalink)
View yowps3's Photo Gallery
NGK & Denso make better components than Bosche.. Trust me
yowps3 is offline   Reply With Quote
Anyone running Iridium spark plugs from Denso TrdTacoma84 2nd Generation (2005+) 43 05-04-2009 10:30 PM
Spark Plugs: Iridium vs. others Zach Ayres Supra Forum 11 12-18-2006 11:37 AM
How long do platinum spark plugs last? NewRacer Camry & Solara Lounge 8 05-24-2006 06:52 PM
Iridium Spark Plugs!?!?!!? Matsu-Seo Yaris, Vitz and Echo Forum 6 12-03-2004 09:52 AM
