3.0 with a strange knock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2006, 08:26 AM   #1 (permalink)
View muddkatt's Photo Gallery
I am putting this in the Camry forum looking for a better response. I have had it up in the Avalon forum for a week with only two replies. Thanks in advance for the help.
My girlfriend has a 2000 Avalon that she bought new, it has about 130000 miles now. It has always been serviced at the stealership with a minimum cover charge of about $500.00. The timing belt was replaced at about 115,000 miles along with an O2 sensor( the one closest to the radiator). About 4000 miles ago she said it started making a knocking noise. NOTE: I never drive her car so I have no clue about when it started. I have not noticed it till this week when it was parked in the driveway and I was letting it idle after I had detailed the Interior for her.It only knocks at low RPM with the air conditioner off. I have checked everywhere and it appears to be something inside the exhaust crossover pipe/Y pipe. it is definitely a knock. It is real damn loud too. It is not a lifter type tick, or a rod knock. And it only does it warm. I am stumped. Help please!!
muddkatt is offline   Reply With Quote
Old 10-10-2006, 12:24 AM   #2 (permalink)
View toyomoho's Photo Gallery
The knock goes away with the A/C on? The magnetic A/C clutch can make a knocking noise. A piece of rubber hose used as a stethoscope can help pin point the location.
Old 10-15-2006, 06:16 AM   #3 (permalink)
When the A/C is turned on the knock stops. But this is due to the increase in rpm, not an A/C issue. It ONLY knocks at idle with the A/C off and the engine at operating temperature. I stethascoped the engine all over, A/C, all components that I could reach and it sounds like it is inside the exhaust crossover piping. I am lost as to what would cause the exhaust to knock.
Fooling the ECM - sharing 1 good knock sensor for 2 ECM inputs Vibroseis Camry & Solara Lounge 14 10-05-2011 10:39 AM
2.4 diesel knock system Andrew G 89-95 Toyota Pickup/Hilux 4 09-20-2006 03:57 PM
2006 Scion xB Release Series 3.0 (official) dlundgren Scion Forum 0 01-06-2006 01:14 PM
Attenuating Knock signal? JoeB Hardcore Tech and Competition 10 04-17-2005 02:35 PM
homemade knock sensor setup? sleepr Hardcore Tech and Competition 4 11-25-2004 08:38 PM
