Hey Liah
hey you should check out the forum question i posted a few weeks ago, its down the page a bit under "Sway Bar Thickness"
it will give you some help and idea on them.
The Strut Bar (would mount to your struts inside your engine bay)is a must, it will stiffen your body and you will notice it has less body roll on turns. That is the best and cheapest route. Check out eBay they have ass loads of strut bars and they are cheap but do what they are supposed to. Reactive the most common brand of strut bar for the Camry and TRD of coarse.
Sway bars (which mount to your undercarriage suspension and steering assembly) will stiifen you ride and give you more control while turning, I would go front (whiteLine) and rear if you have the money. Trd makes a rear for a 99 Solara but it will fit your car also. I am in the process of getting both. But if you only go one route, at least get the strut bar and maybe the front sway bar.
Good Luck on the Exhaust, stick with CT Motorsport. Sean Miller (SoundLzd) is a good guy an dhe will take care of you. (Greddy Evo) (Apexi) is your only choice.
Sean Armstrong
Check out my 97 Camry and tell me what you think.
www.cardomain.com/id/guidoxpress
I would like to thank my good friend Mike Phoung at JT Autostyle for my new Sponsoship. Check out there website for details on bodykits.
www.JTAutostyle.com
