Big Problem HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2003, 12:21 PM   #1 (permalink)
3sgte'd
WickedWerx's Avatar
View WickedWerx's Photo Gallery
Big Problem HELP
I have no more power windows or locks..... Its not a fuse i checked them all. I am out of solutions any idea guys
Tony R
WickedWerx is offline   Reply With Quote
Old 05-01-2003, 12:36 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
If you're positive it's not the fuses, the next thing to check would be switches, then mechanical cables, then motors.
Phi is offline   Reply With Quote
Old 05-02-2003, 12:35 AM   #3 (permalink)
View warlock's Photo Gallery
switches or the wires dude.the best thing to do is pull your drive door panale off and remove the switches (if thay go out thay all go out)have a electric tester and set it on ohm and test each one if all good go to the next door
warlock is offline   Reply With Quote
Old 05-05-2003, 01:03 PM   #4 (permalink)
View NextlevelCamry's Photo Gallery
you must have a break in the circuit somewhere, the circuit may have a ground problem, does anything else happen when you try and use the windows or locks? if something else comes on then you may have a short.
NextlevelCamry is offline   Reply With Quote
Old 05-05-2003, 02:01 PM   #5 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Read this thread:
http://www.toyotanation.com/showthre...hlight=windows
Silver Streak is offline   Reply With Quote
