Progressive Door Unlock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2003, 01:31 PM   #1 (permalink)
View Ice5's Photo Gallery
Hi.
So I have a 1992 Camry. When you unlock the car with the key, the doors progressively unlock. i.e. Turn the key once and the drivers door unlocks, turn it a second time and the rest of the doors unlock.
I installed a Hornet 554T alarm on Tuesday and everything works great. However I would like to have the doors progressively unlock. Not a BIG deal, but if it can be done I would like to.
Now, I have the DEI wire listing for my car and it lists the lock/unlock wires for my car. Right now I have the alarm hooked up to these wires and all doors unlock when I disarm the system.
There is a second lock output on my alarm, and I'm wondering how I should wire up the Camry for this feature.
I'm going to go play around with a multi meter later, but I was hoping that someone here had done this before.
Thanks,
Cam
Ice5 is offline   Reply With Quote
Old 05-01-2003, 02:06 PM   #2 (permalink)
View DIRTBIKEZ's Photo Gallery
Did you already read through the Doc. 1041 we got from Camry9294? It seemed to have some pertinant information on pages 20 and 21. If only i had some time, I'd dig into it further.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 05-01-2003, 02:30 PM   #3 (permalink)
View Camry9294's Photo Gallery
Hey guys, It doesn't look that hard as far as prewiring the prog. lock set up. I think finding the proper wire in the drivers door is the key. Maybe if you probe around the key cylinder you might find it.
06 Sienna LE AWD Pkg. # 2
98 Camry LE 5SFE
Light travels faster than sound, that's why some people seem bright until you hear them speak
Camry9294 is offline   Reply With Quote
Old 05-01-2003, 03:50 PM   #4 (permalink)
Hey Dirtbikez... Yeah, I posted before I got 1041...
Plus, I was hoping that someone had done this before.
Anyway, I'll leave them as is for now, and later this summer I'll attack the progressive part.
Thanks again.
Old 05-02-2003, 04:49 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Progressive Door Unlock
Are you sure that it has 2 sets of lock outputs?
Your probably confused about the + (positive) and - (negative) lock / unlock triggers.
Toyota's use a negative trigger for the door lock / unlock.
"Skoolin' the unlearned!"
Old 05-02-2003, 07:25 PM   #6 (permalink)
Ice5 is right. The h2/3 Violet/black 200ma(-) wire, which happens to be the channel 4 output can be programmed to pulse when the remote is pressed again within 15 seconds after the first unlock. This allows you to have the progressive door lock feature.
98 Camry LE 5SFE
Old 09-25-2004, 11:57 AM   #7 (permalink)
View cmhoang's Photo Gallery
This is a question. The progressive unlock on my 92 Camry does not work. I check all the wires and they are OK. What could be the cause how to fix it. Thanks.
cmhoang is offline   Reply With Quote
